[Bio] / FigKernelScripts / svr_pegs_in_subsystems.pl Repository:
Log of /FigKernelScripts/svr_pegs_in_subsystems.pl
Links to mgrast_dev_05262011: (view) (download) (as text) (annotate)
Mon Apr 4 19:25:34 2011 UTC (8 years, 9 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.6: +64 -39 lines
Fixed to process 10 subsystems at a time, reducing the chances of a timeout.
Thu Jul 29 14:48:54 2010 UTC (9 years, 5 months ago) by parrello
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, myrast_33, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.5: +9 -4 lines
More server scripts.
Wed Feb 17 15:03:27 2010 UTC (9 years, 11 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Fixed POD errors. Added examples.
Tue Oct 20 20:22:08 2009 UTC (10 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.3: +60 -33 lines
More extensive documentation for the various server scripts.
Wed Oct 7 21:04:43 2009 UTC (10 years, 3 months ago) by parrello
Fixed error in SS call.
Fri Jul 17 19:45:18 2009 UTC (10 years, 6 months ago) by disz
CVS Tags: rast_rel_2009_0925
Changes since 1.1: +28 -22 lines
fixed up noroles with group, noroles w/o group
Wed Jul 15 23:36:53 2009 UTC (10 years, 6 months ago) by parrello
Diff to selected 1.5
New scripts for operon pipeline.
