[Bio] / FigKernelScripts / svr_motif.pl Repository:
Log of /FigKernelScripts/svr_motif.pl
Sun Apr 3 19:36:49 2011 UTC (8 years, 10 months ago) by fangfang
CVS Tags: HEAD, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +1 -2 lines
simplify code
Sun Apr 3 17:24:06 2011 UTC (8 years, 10 months ago) by fangfang
pod update
Sun Apr 3 17:02:24 2011 UTC (8 years, 10 months ago) by fangfang
Changes since 1.1: +55 -1 lines
added pod
Sun Apr 3 16:54:11 2011 UTC (8 years, 10 months ago) by fangfang
script for extracting conserved regions from alignment
