[Bio] / FigKernelScripts / svr_kill_RAST_job.pl Repository:
Log of /FigKernelScripts/svr_kill_RAST_job.pl
Thu Nov 19 16:49:22 2009 UTC (10 years, 6 months ago) by olson
fix usage message
Thu Oct 29 16:20:08 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.2: +4 -2 lines
Fix 666666 problem.
Add support for using the test server.
Mon Oct 26 18:19:57 2009 UTC (10 years, 7 months ago) by olson
Changes since 1.1: +5 -0 lines
Add SAS comments.
Add real implementation of user_may_access_job and user_owns_job in RAST_submission
so that the batch interface obeys the permissions set up by the RAST server.
Thu Oct 22 21:15:13 2009 UTC (10 years, 7 months ago) by olson
Diff to selected 1.4
Lastest code. working submissions, plus kill & delete job.
