[Bio] / FigKernelScripts / svr_just_ends.pl Repository:
Log of /FigKernelScripts/svr_just_ends.pl
Sat Feb 12 21:26:02 2011 UTC (8 years, 9 months ago) by redwards
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
increasing min length to 2000 so that you have two ends!
Sat Feb 12 21:22:22 2011 UTC (8 years, 9 months ago) by redwards
adding a missing > in ids
Sun Nov 7 00:24:36 2010 UTC (9 years ago) by overbeek
tools to try to bridge contigs
