[Bio] / FigKernelScripts / svr_is_hypo.pl Repository:
Log of /FigKernelScripts/svr_is_hypo.pl
Thu Apr 7 22:11:18 2011 UTC (9 years, 3 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +14 -2 lines
minor fixes
Thu Apr 7 15:25:56 2011 UTC (9 years, 3 months ago) by parrello
Fixed a pod error.
Sat Apr 2 15:17:55 2011 UTC (9 years, 3 months ago) by overbeek
CVS Tags: mgrast_dev_04052011, mgrast_release_3_0_3
add script to filter on hypothetical
