[Bio] / FigKernelScripts / svr_ids_to_figfams.pl Repository:
Log of /FigKernelScripts/svr_ids_to_figfams.pl
Sun Oct 17 01:07:46 2010 UTC (9 years, 4 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.7: +3 -4 lines
fixes to documentation
Mon Sep 13 20:49:53 2010 UTC (9 years, 5 months ago) by disz
CVS Tags: rast_rel_2010_0928
Added stderr output for non-matches
Wed Jul 28 16:21:29 2010 UTC (9 years, 6 months ago) by parrello
CVS Tags: rast_rel_2010_0827
Changes since 1.5: +9 -3 lines
More server script stuff. Thought I'd already installed these last week...
Wed Feb 17 15:03:27 2010 UTC (10 years ago) by parrello
CVS Tags: rast_rel_2010_0526
Fixed POD errors. Added examples.
Wed Dec 2 00:41:24 2009 UTC (10 years, 2 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Fixed a bug in the output handling.
Thu Oct 29 18:29:51 2009 UTC (10 years, 3 months ago) by parrello
Changes since 1.2: +12 -32 lines
Final Server updates.
Tue Oct 20 20:22:08 2009 UTC (10 years, 4 months ago) by parrello
Changes since 1.1: +74 -50 lines
More extensive documentation for the various server scripts.
Sun Oct 11 22:11:29 2009 UTC (10 years, 4 months ago) by parrello
New scripts for Ying.
