[Bio] / FigKernelScripts / svr_get_default_dataset.pl Repository:
Log of /FigKernelScripts/svr_get_default_dataset.pl
Tue Sep 27 22:47:58 2011 UTC (8 years, 1 month ago) by olson
CVS Tags: HEAD, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
script to retrieve the name of the current default kmer datasets
