[Bio] / FigKernelScripts / svr_genbank_to_table.pl Repository:
Log of /FigKernelScripts/svr_genbank_to_table.pl
Sun Aug 29 22:23:20 2010 UTC (9 years, 2 months ago) by gdpusch
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.1: +19 -20 lines
Added various alias IDs to output.
Wed Aug 18 20:35:23 2010 UTC (9 years, 3 months ago) by gdpusch
CVS Tags: rast_rel_2010_0827
Initial checkin
