[Bio] / FigKernelScripts / svr_function_of.pl Repository:
Log of /FigKernelScripts/svr_function_of.pl
Links to mgrast_dev_08022011: (view) (download) (as text) (annotate)
Tue May 31 20:39:41 2011 UTC (8 years, 11 months ago) by parrello
CVS Tags: mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_rel40, rast_rel_2011_0928
Changes since 1.10: +16 -13 lines
Diff to previous 1.10 , to selected 1.5
Converted to use "GetBatch" to flow-control the requests.
Mon Apr 18 00:33:41 2011 UTC (9 years, 1 month ago) by overbeek
CVS Tags: mgrast_dev_05262011
Diff to previous 1.9 , to selected 1.5
handle undefined function
Wed Mar 16 20:09:30 2011 UTC (9 years, 2 months ago) by overbeek
CVS Tags: mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.8: +1 -0 lines
Diff to previous 1.8 , to selected 1.5
handle empty input
Wed Mar 16 20:05:00 2011 UTC (9 years, 2 months ago) by overbeek
Changes since 1.7: +2 -0 lines
Diff to previous 1.7 , to selected 1.5
handle no function
Tue Oct 5 15:49:35 2010 UTC (9 years, 7 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_release_3_0, mgrast_release_3_0_1, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.6: +3 -6 lines
fix parsing options
Wed Aug 11 18:08:28 2010 UTC (9 years, 9 months ago) by parrello
Changes since 1.5: +9 -1 lines
POD fixes, new support for annotation download.
Wed Jul 28 16:21:29 2010 UTC (9 years, 9 months ago) by parrello
More server script stuff. Thought I'd already installed these last week...
Fri Dec 11 21:54:44 2009 UTC (10 years, 5 months ago) by disz
CVS Tags: rast_rel_2010_0118, rast_rel_2010_0526
SAS component
Sat Nov 7 16:56:45 2009 UTC (10 years, 6 months ago) by overbeek
Changes since 1.2: +46 -75 lines
server scripts for basic utilities
Revision 1.2
Thu Oct 29 18:29:51 2009 UTC (10 years, 6 months ago) by parrello
FILE REMOVED
Final Server updates.
Tue Oct 20 20:22:08 2009 UTC (10 years, 7 months ago) by parrello
Diff to selected 1.5
More extensive documentation for the various server scripts.
