[Bio] / FigKernelScripts / svr_figfams_to_ids.pl Repository:
Log of /FigKernelScripts/svr_figfams_to_ids.pl
Thu Oct 21 13:02:28 2010 UTC (9 years, 1 month ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Added "roles_to_subsys", sped up "figfams_to_ids", fixed pod for "mapped_genomes".
Tue Oct 19 17:20:31 2010 UTC (9 years, 1 month ago) by parrello
Changes since 1.4: +13 -11 lines
Attempted to improve performance.
Wed Sep 15 15:22:25 2010 UTC (9 years, 2 months ago) by overbeek
CVS Tags: rast_rel_2010_0928
Changes since 1.3: +9 -1 lines
speed up by avoiding duplicate requests
Tue Sep 14 17:19:24 2010 UTC (9 years, 2 months ago) by parrello
Changed to use batch FIGfam retrieval service.
Mon Sep 13 22:06:30 2010 UTC (9 years, 2 months ago) by overbeek
from FIGfams to PEGs
Mon Sep 13 21:58:33 2010 UTC (9 years, 2 months ago) by overbeek
not debugged yet
