[Bio] / FigKernelScripts / svr_fig_id_corr.pl Repository:
Log of /FigKernelScripts/svr_fig_id_corr.pl
Thu Dec 10 23:17:56 2009 UTC (10 years, 3 months ago) by overbeek
add -precise option
Thu Dec 10 23:12:11 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.2: +21 -5 lines
add -precise option
Tue Dec 8 21:17:13 2009 UTC (10 years, 3 months ago) by overbeek
get rid of progress msg
Tue Dec 8 21:08:25 2009 UTC (10 years, 3 months ago) by overbeek
generate current id correspondence
