[Bio] / FigKernelScripts / svr_fasta.pl Repository:
Log of /FigKernelScripts/svr_fasta.pl
Thu Dec 30 17:10:55 2010 UTC (8 years, 10 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
wrap the seq into 60-char lines
Thu Dec 30 16:53:24 2010 UTC (8 years, 10 months ago) by overbeek
Changes since 1.12: +13 -3 lines
add function and genome to fasta header
Wed Aug 11 18:08:28 2010 UTC (9 years, 3 months ago) by parrello
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206
POD fixes, new support for annotation download.
Wed Jul 28 16:21:29 2010 UTC (9 years, 3 months ago) by parrello
Changes since 1.10: +11 -4 lines
More server script stuff. Thought I'd already installed these last week...
Wed Feb 17 15:03:27 2010 UTC (9 years, 9 months ago) by parrello
CVS Tags: rast_rel_2010_0526
Changes since 1.9: +2 -0 lines
Fixed POD errors. Added examples.
Wed Dec 16 17:11:42 2009 UTC (9 years, 11 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Changes since 1.8: +3 -2 lines
Fixed the comments to recognize the new defaults.
Fri Dec 11 22:02:54 2009 UTC (9 years, 11 months ago) by disz
Changes since 1.7: +4 -4 lines
New style calls
Fri Dec 11 21:51:12 2009 UTC (9 years, 11 months ago) by disz
Changes since 1.6: +12 -11 lines
New style SAP server calls
Thu Dec 10 19:31:12 2009 UTC (9 years, 11 months ago) by olson
changes for new server stuff
Tue Nov 3 16:35:11 2009 UTC (10 years ago) by parrello
Changes since 1.4: +5 -2 lines
Changed batch size to 10 for DNA fasta display to avoid timeouts on euks.
Thu Oct 29 18:29:51 2009 UTC (10 years ago) by parrello
Changes since 1.3: +16 -35 lines
Final Server updates.
Tue Oct 20 20:22:08 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.2: +50 -54 lines
More extensive documentation for the various server scripts.
Sun Oct 11 22:12:06 2009 UTC (10 years, 1 month ago) by parrello
Changes since 1.1: +6 -6 lines
Fixed the POD comments.
Sun Oct 11 19:56:46 2009 UTC (10 years, 1 month ago) by parrello
New command for Steve Smith.
