[Bio] / FigKernelScripts / svr_expressed_genes_in_range.pl Repository:
Log of /FigKernelScripts/svr_expressed_genes_in_range.pl
Thu Mar 31 20:25:21 2011 UTC (8 years, 8 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Added for looking at genes that are never or always expressed.
