[Bio] / FigKernelScripts / svr_export_as_seed_dir.pl Repository:
Log of /FigKernelScripts/svr_export_as_seed_dir.pl
Thu Jul 21 20:06:09 2011 UTC (8 years, 6 months ago) by olson
CVS Tags: HEAD, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
bugfix, get all subsystem records.
Fri Jul 8 20:22:20 2011 UTC (8 years, 7 months ago) by olson
Changes since 1.1: +39 -5 lines
Add subsystem write support.
Fri Jul 8 19:54:01 2011 UTC (8 years, 7 months ago) by olson
Export a Sapling genome as a seed directory, with optional renaming.
