[Bio] / FigKernelScripts / svr_enumerate_sets_by_owner.pl Repository:
View of /FigKernelScripts/svr_enumerate_sets_by_owner.pl
Thu Sep 22 20:52:36 2011 UTC (8 years, 2 months ago) by disz
CVS Tags: rast_rel_2014_0912, rast_rel_2014_0729, mgrast_release_3_1_2, rast_rel_2011_0928, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_10262011, HEAD
New persistent set svr scripts
use strict;
use Getopt::Long;
use SeedEnv;
use PersistentSets;
# This is a SAS Component
=head1 svr_enumerate_sets_by_owner
List all the persistent sets owned by owner
The output is a list of sets names
Example: svr_enumerate_sets_by_owner -owner owner_name  > allsets.tbl
would produce a 1-column table of the owner:set_name of the persistent sets owned by owner_name.
=head2 Command-Line Options
=over 4
=item url
The URL for the Sapling server, if it is to be different from the default.
=item owner
If supplied, sets for the owner name will be supplied, if not supplied, owner name(s) are read from stdin
=back
=head2 Output Format
The standard output is a file where each line contains an owner name and a  set name
=cut
my $usage    = "usage: svr_enumerate_sets_by_owner [--owner=owner_name] >output\n";
my $owner = "";
my $url = '';
my $column;
my $opted    = GetOptions('c=i' => \$column, 'owner=s', \$owner, 'url=s', \$url);
if (! $opted) {
    print $usage;
} else {
    if (!$owner) {
	 my @owners = ScriptThing::GetList(\*STDIN, $column);
	for $owner (@owners) {
		get_sets($owner);
    } else {
	get_sets($owner);
sub get_sets {
    my ($owner) = @_;
    my $sets = PersistentSets::enumerate_sets_by_owner($owner);
    for my $set (@$sets) {
	print "$owner:$set\n";
