[Bio] / FigKernelScripts / svr_corr_by_exp.pl Repository:
Log of /FigKernelScripts/svr_corr_by_exp.pl
Mon Apr 4 02:57:39 2011 UTC (9 years, 2 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_rel40, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +17 -21 lines
Changed to batch the input instead of slurping it.
Sat Apr 2 14:59:17 2011 UTC (9 years, 2 months ago) by overbeek
Changes since 1.3: +16 -3 lines
add cutoffs
Tue Feb 8 20:06:35 2011 UTC (9 years, 3 months ago) by overbeek
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, myrast_33
get format right for print
Tue Feb 8 20:04:44 2011 UTC (9 years, 3 months ago) by overbeek
Changes since 1.1: +11 -3 lines
get genes correlated by expression
Tue Feb 8 19:58:53 2011 UTC (9 years, 3 months ago) by overbeek
Diff to selected 1.2
