[Bio] / FigKernelScripts / svr_contigs_in_genome.pl Repository:
Log of /FigKernelScripts/svr_contigs_in_genome.pl
Tue Aug 10 17:51:01 2010 UTC (9 years, 10 months ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +5 -2 lines
Added support for specifying input IDs on the command line.
Wed Jul 21 18:57:31 2010 UTC (9 years, 11 months ago) by parrello
Changes since 1.1: +1 -3 lines
New script, some documentation fixes.
Tue Jul 20 21:12:12 2010 UTC (9 years, 11 months ago) by parrello
Diff to selected 1.3
First round of script updates & additions for tutorial.
