[Bio] / FigKernelScripts / svr_contigs_in_genome.pl Repository:
View of /FigKernelScripts/svr_contigs_in_genome.pl
Tue Jul 20 21:12:12 2010 UTC (9 years, 11 months ago) by parrello
First round of script updates & additions for tutorial.
#!/usr/bin/perl -w
use strict;
use Getopt::Long;
use SAPserver;
use ScriptThing;
#	This is a SAS Component.
=head1 svr_contigs_in_genome
    svr_contigs_in_genome <genome_ids.tbl >genome_data.tbl
For each incoming genome ID, return the IDs of its contigs.
This script takes as input a tab-delimited file with genome IDs at the end of each
line. For each genome ID, multiple output lines are produced containing the ID
of each contig in the genome.
This is a pipe command: the input is taken from the standard input and the output
is to the standard output.
=head2 Command-Line Options
=over 4
=item url
The URL for the Sapling server, if it is to be different from the default.
=item c
Column index. If specified, indicates that the input IDs should be taken from the
indicated column instead of the last column. The first column is column 1.
=back
=cut
# Parse the command-line options.
my $url = '';
my $column = '';
my $opted =  GetOptions('url=s' => \$url, 'c=i' => \$column);
if (! $opted) {
    print "usage: svr_contigs_in_genome [--url=http://...] <input >output\n";
} else {
    # Get the list of output field names from the remaining positional parameters.
    my @outputs = @ARGV;
    # Get the server object.
    my $sapServer = SAPserver->new(url => $url);
    # The main loop processes chunks of input.
    while (my @tuples = ScriptThing::GetBatch(\*STDIN, undef, $column)) {
        # Ask the server for results.
        my $document = $sapServer->genome_contigs(-ids => [map { $_->[0] } @tuples]);
        # Loop through the IDs, producing output.
        for my $tuple (@tuples) {
            my ($id, $line) = @$tuple;
            # Get this genome's data.
            my $genomeData = $document->{$id};
            # Did we get something?
            if (! $genomeData) {
                # No. Write an error notification.
                print STDERR "None found: $id\n";
            } else {
                # Yes. Print the output lines.
                for my $contigID (@$genomeData) {
                    print join("\t", $line, $contigID) . "\n";
