[Bio] / FigKernelScripts / svr_co_occurrence_evidence.pl Repository:
Log of /FigKernelScripts/svr_co_occurrence_evidence.pl
Thu Nov 11 17:25:48 2010 UTC (9 years, 3 months ago) by disz
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
FigFam 6 digit problem
Tue Sep 14 19:23:45 2010 UTC (9 years, 5 months ago) by overbeek
CVS Tags: rast_rel_2010_0928
Changes since 1.2: +112 -6 lines
handles FF or PEGs
Tue Sep 14 17:38:16 2010 UTC (9 years, 5 months ago) by overbeek
Changes since 1.1: +7 -8 lines
make it pegs
Tue Sep 14 17:30:29 2010 UTC (9 years, 5 months ago) by overbeek
try
