[Bio] / FigKernelScripts / svr_assign_using_figfams.pl Repository:
Log of /FigKernelScripts/svr_assign_using_figfams.pl
Wed Sep 28 20:42:00 2011 UTC (8 years, 6 months ago) by olson
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Changes since 1.11: +6 -0 lines
Add kmerDataset selection support.
Fri Jan 21 14:04:26 2011 UTC (9 years, 2 months ago) by gdpusch
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_33, myrast_rel40, rast_rel_2011_0119
Changes since 1.10: +5 -4 lines
Fixed "die" statement that lacks any conditional.
Sun Jan 16 18:33:46 2011 UTC (9 years, 2 months ago) by gdpusch
Changes since 1.9: +3 -1 lines
Added informative trap-and-die when ANNOserver::assign_function_to_prot() returns an undef.
Wed Nov 3 20:17:09 2010 UTC (9 years, 4 months ago) by olson
CVS Tags: rast_rel_2010_1206
Changes since 1.8: +11 -3 lines
add -fam opt
Mon Aug 23 18:10:44 2010 UTC (9 years, 7 months ago) by redwards
Changes since 1.7: +7 -1 lines
updating docs
Mon Mar 1 21:14:22 2010 UTC (10 years ago) by olson
CVS Tags: rast_rel_2010_0526
Changes since 1.6: +5 -1 lines
Add support for --kmerDataset flag
Fri Feb 19 17:32:56 2010 UTC (10 years, 1 month ago) by olson
Changes since 1.5: +0 -3 lines
Remove debugging.
Wed Feb 17 15:03:27 2010 UTC (10 years, 1 month ago) by parrello
Fixed POD errors. Added examples.
Thu Dec 17 21:38:00 2009 UTC (10 years, 3 months ago) by olson
CVS Tags: rast_rel_2010_0118
fix ANNOserver args
Thu Dec 10 19:31:12 2009 UTC (10 years, 3 months ago) by olson
Changes since 1.2: +16 -15 lines
changes for new server stuff
Thu Oct 29 18:29:51 2009 UTC (10 years, 5 months ago) by parrello
Changes since 1.1: +10 -2 lines
Final Server updates.
Tue Oct 20 20:22:08 2009 UTC (10 years, 5 months ago) by parrello
More extensive documentation for the various server scripts.
