[Bio] / FigKernelScripts / svr_aligns_with_prot.pl Repository:
Log of /FigKernelScripts/svr_aligns_with_prot.pl
Wed Dec 11 19:22:22 2013 UTC (5 years, 11 months ago) by golsen
Provide a command line mechanism to get the alignments associated with
one or more fids and/or md5s. Default behavior is standard "add fields".
--text flag is good for people.
