[Bio] / FigKernelScripts / submit_ff_test.pl Repository:
Log of /FigKernelScripts/submit_ff_test.pl
Thu Oct 8 18:54:18 2009 UTC (10 years, 1 month ago) by arodri7
Changes since 1.5: +34 -10 lines
commit changes
Mon Dec 22 07:17:06 2008 UTC (10 years, 10 months ago) by arodri7
CVS Tags: rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925
added changes to update procedure
Wed Jun 18 15:18:26 2008 UTC (11 years, 4 months ago) by arodri7
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_release_2008_09_29
Changes since 1.3: +23 -7 lines
update changes
Thu Apr 10 00:52:46 2008 UTC (11 years, 7 months ago) by overbeek
simplified versions
Mon Apr 7 21:38:31 2008 UTC (11 years, 7 months ago) by overbeek
Changes since 1.1: +11 -7 lines
fixes to quality control for FigFams
Mon Mar 31 18:15:58 2008 UTC (11 years, 7 months ago) by arodri7
added the figfam quality control processes to the overall update process
