[Bio] / FigKernelScripts / splitup.pl Repository:
Log of /FigKernelScripts/splitup.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 2 months ago) by olson
Mon Jul 26 20:54:28 2004 UTC (15 years, 6 months ago) by gdpusch
Changes since 1.2: +5 -3 lines
Added error-checking.
Sat Dec 6 20:59:45 2003 UTC (16 years, 2 months ago) by overbeek
allow chunk size as a parameter on splitup
Mon Dec 1 20:46:40 2003 UTC (16 years, 2 months ago) by efrank
Makefile:
All the rest:
