[Bio] / FigKernelScripts / split_sims.pl Repository:
Log of /FigKernelScripts/split_sims.pl
Mon Dec 5 18:56:38 2005 UTC (14 years, 2 months ago) by olson
Fri Mar 11 16:17:08 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.1: +12 -7 lines
Modified to take input from either STDIN or files; added more informative error-msgs. -- /gdp
Wed Mar 17 15:37:06 2004 UTC (15 years, 11 months ago) by overbeek
sims stuff
