[Bio] / FigKernelScripts / split_sequences_into_sets.pl Repository:
Log of /FigKernelScripts/split_sequences_into_sets.pl
Tue Aug 25 16:30:16 2009 UTC (10 years, 3 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
handle asym connections
Mon Aug 24 16:29:17 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.3: +9 -4 lines
stop drift
Sun Aug 23 18:40:43 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.2: +19 -48 lines
redone entirely
Wed Aug 19 16:11:28 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.1: +76 -186 lines
complete rewrite
Mon Aug 3 19:48:53 2009 UTC (10 years, 4 months ago) by overbeek
add ability to split a set of sequences into alignable subsets
