[Bio] / FigKernelScripts / split_sequences_into_sets.pl Repository:
View of /FigKernelScripts/split_sequences_into_sets.pl
Revision 1.4 - (download) (as text) (annotate)
Mon Aug 24 16:29:17 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.3: +9 -4 lines
stop drift
# -*- perl -*-
# Public License.
use strict;
use FIG;
use ProtSims;
use gjoseqlib;
my $min_sz  = 30;
my $fullF   = "/tmp/seqs.$$";
my $usage = "usage: split_sequences_into_sets OutputDirectory [SimilarityCutoff FracCoverage] < full_seqs";
my $output;
 ($output = shift @ARGV)
    || die $usage;
(! -e $output) || die "$output already exists -- check it (and delete it, if that is what you really wish)";
&FIG::verify_dir($output);
my @seqs = &gjoseqlib::read_fasta();
my %seq_of = map { $_->[0] => $_->[2] } @seqs;
my($sim_cutoff,$frac_cov);
if (@ARGV == 2)
    $sim_cutoff = shift @ARGV;
    $frac_cov   = shift @ARGV;
else
    $sim_cutoff = 1.0e-30;
    $frac_cov   = 0.70;
my $min_size = (@seqs > 20) ? (@seqs / 10) : (@seqs / 2);
my @all = map { my($id1,$id2,undef,undef,undef,undef,$b1,$e1,$b2,$e2,$psc,undef,$ln1,$ln2) = @$_;
	        [$id1,$id2,(($e1+1)-$b1)/$ln1,(($e2+1)-$b2)/$ln2,$psc]
	      } &ProtSims::blastP(\@seqs,\@seqs,$min_size);
my @sims = grep { my($id1,$id2,$frac1,$frac2,$psc) = @$_;
	          ($id1 ne $id2) && ($frac1 >= $frac_cov) && ($frac2 >= $frac_cov) } @all;
my(%seen,%conn);
foreach my $sim (@sims)
    my($id1,$id2,$frac1,$frac2,$psc) = @$sim;
    my $key = join("\t",sort ($id1,$id2));
    if (! $seen{$key})
	$seen{$key} = 1;
	push(@{$conn{$id1}},$id2);
	push(@{$conn{$id2}},$id1);
undef %seen;
my @ids = sort { my $x = $conn{$b} ? @{$conn{$b}} : 0;
		 my $y = $conn{$a} ? @{$conn{$a}} : 0;
		 ($x <=> $y)
	       } keys(%seq_of);
my $n = 1;
my @sets = ();
open(SZ,">$output/set.sizes") || die "could not open $output/set.sizes";
foreach my $central_id (@ids)
    if (! $seen{$central_id})
	my $set = &extract_set($central_id,\%conn,\%seen,\%seq_of);
	print SZ join("\t",($n,scalar @$set)),"\n";
	push(@sets,[$n,$set]);
	open(OUT,">$output/$n") || die "could not open $output/$n";
	$n++;
	foreach my $peg (@$set)
	    $seen{$peg} = 1;
	    print OUT ">$peg\n$seq_of{$peg}\n";
	close(OUT);
close(SZ);
my @distances = &construct_distance_matrix(\@sets,\@all); # entries are [n1,n2,sc]
open(DIST,">$output/distance.matrix\n") || die "could not open $output/distance.matrix";
foreach my $tuple (@distances)
    print DIST join("\t",@$tuple),"\n";
close(DIST);
sub run {
    my($cmd) = @_;
#   my @tmp = `date`; chomp @tmp; print STDERR "$tmp[0]: running $cmd\n";
    (system($cmd) == 0) || confess "FAILED: $cmd";
sub extract_set {
    my($central_id,$conn,$seen,$seq_of) = @_;
    my $center_length = length($seq_of->{$central_id});
    my $cluster = [$central_id];
    my %in      = ($central_id,1);
    my $i;
    while ($i < @$cluster)
	my $x = $conn->{$cluster->[$i]};
	$i++;
	foreach my $peg (@$x)
	    if (! $in{$peg})
		my $len = length($seq_of->{$peg});
		if ((abs($center_length - $len) / $center_length) <= (1 - $frac_cov))
		    push(@$cluster,$peg);
		    $in{$peg} = 1;
    return $cluster;
sub construct_distance_matrix {
    my($sets,$sims) = @_;
    my($tuple,$n,$set,$id1,$id2,$sc,$sim,%best,$key,$n1,$n2);
    my(@distances,$sofar,%in);
    foreach my $tuple (@$sets)
	my($n,$set) = @$tuple;
	foreach my $id (@$set)
	    $in{$id} = $n;
    my %best;
    foreach my $sim (@$sims)
	my($id1,$id2,undef,undef,$sc) = @$sim;
	if ($in{$id1} && $in{$id2} && ($in{$id1} != $in{$id2}))
	    my $key = join("\t",($in{$id1},$in{$id2}));
	    if ((! ($sofar = $best{$key})) || ($sofar < $sc))
		$best{$key} = $sc;
	    $key = join("\t",($in{$id2},$in{$id1}));
	    if ((! ($sofar = $best{$key})) || ($sofar > $sc))
		$best{$key} = $sc;
    my @distances = ();
    foreach my $key (keys(%best))
	my($n1,$n2) = split(/\t/,$key);
	push(@distances,[$n1,$n2,$best{$key}]);
    return sort { ($a->[0] <=> $b->[0]) or ($a->[1] <=> $b->[1]) } @distances;
