[Bio] / FigKernelScripts / split_sequences_into_sets.pl Repository:
View of /FigKernelScripts/split_sequences_into_sets.pl
Revision 1.2 - (download) (as text) (annotate)
Wed Aug 19 16:11:28 2009 UTC (10 years, 3 months ago) by overbeek
Changes since 1.1: +76 -186 lines
complete rewrite
# -*- perl -*-
# Public License.
use strict;
use FIG;
use ProtSims;
use gjoseqlib;
my $min_sz  = 30;
my $fullF   = "/tmp/seqs.$$";
my $usage = "usage: split_sequences_into_sets OutputDirectory [SimilarityCutoff FracCoverage] < full_seqs";
my $output;
 ($output = shift @ARGV)
    || die $usage;
(! -e $output) || die "$output already exists -- check it (and delete it, if that is what you really wish)";
&FIG::verify_dir($output);
my @seqs = &gjoseqlib::read_fasta();
my %seq_of = map { $_->[0] => $_->[2] } @seqs;
my($sim_cutoff,$frac_cov);
if (@ARGV == 2)
    $sim_cutoff = shift @ARGV;
    $frac_cov   = shift @ARGV;
else
    $sim_cutoff = 1.0e-30;
    $frac_cov   = 0.70;
my $min_size = (@seqs > 20) ? (@seqs / 10) : (@seqs / 2);
my @all = &ProtSims::blastP(\@seqs,\@seqs,$min_size);
# &print_sims(\@all);
# $_ = @all; print STDERR "computed $_ similarities\n";
my @sims = grep { ($_->id1 ne $_->id2) &&
	          ($_->psc <= $sim_cutoff) &&
                  ((($_->e1 - $_->b1) / $_->ln1) >= $frac_cov) &&
                  ((($_->e2 - $_->b2) / $_->ln2) >= $frac_cov)
                } @all;
# print STDERR "=======\n";
# &print_sims(\@sims);
my(%seen,%conn);
foreach my $sim (@sims)
    if (! $seen{"$sim->id1\t$sim->id2"})  # pick only the best similarity between two ids
	push(@{$conn{$sim->id1}},$sim);
	$seen{"$sim->id1\t$sim->id2"} = 1;
undef %seen;
# print STDERR "built connections\n";
my @ids = sort { &cov($conn{$b}) <=> &cov($conn{$a}) }
          keys(%seq_of);
# sort by sum of coverage
my $n = 1;
my @sets = ();
open(SZ,">$output/set.sizes") || die "could not open $output/set.sizes";
foreach my $central_id (@ids)
    if (! $seen{$central_id})
	my $set = &extract_set($central_id,\%conn,\%seen);
	print SZ join("\t",($n,scalar @$set)),"\n";
	push(@sets,[$n,$set]);
	open(OUT,">$output/$n") || die "could not open $output/$n";
	$n++;
	foreach my $peg (@$set)
	    $seen{$peg} = 1;
	    print OUT ">$peg\n$seq_of{$peg}\n";
	close(OUT);
close(SZ);
# print STDERR "built set sizes\n";
my @distances = &construct_distance_matrix(\@sets,\@all); # entries are [n1,n2,sc]
open(DIST,">$output/distance.matrix\n") || die "could not open $output/distance.matrix";
foreach my $tuple (@distances)
    print DIST join("\t",@$tuple),"\n";
close(DIST);
# print STDERR "built distance matrix\n";
sub print_sims {
    my($sims) = @_;
    foreach my $sim (@$sims)
	print STDERR join("\t",($sim->id1,$sim->id2,$sim->iden,$sim->b1,$sim->e1,$sim->b2,$sim->e2,$sim->psc,$sim->ln1,$sim->ln2)),"\n";
sub cov {
    my($sims) = @_;
    my($x,$n);
    $n = 0;
    foreach $x (@$sims)
	$n += ($x->e1 - $x->b1);
    return $n;
sub run {
    my($cmd) = @_;
#   my @tmp = `date`; chomp @tmp; print STDERR "$tmp[0]: running $cmd\n";
    (system($cmd) == 0) || confess "FAILED: $cmd";
sub extract_set {
    my($central_id,$conn,$seen) = @_;
    my $cluster = [$central_id];
    my %in      = ($central_id,1);
    my $i;
    while ($i < @$cluster)
	my $x = $conn->{$cluster->[$i]};
	$i++;
	foreach my $peg (map { $_->id2} @$x)
	    if (! $in{$peg})
		push(@$cluster,$peg);
		$in{$peg} = 1;
    return $cluster;
sub construct_distance_matrix {
    my($sets,$sims) = @_;
    my($tuple,$n,$set,$id1,$id2,$sc,$sim,%best,$key,$n1,$n2);
    my(@distances,$sofar,%in);
    foreach my $tuple (@$sets)
	my($n,$set) = @$tuple;
	foreach my $id (@$set)
	    $in{$id} = $n;
    my %best;
	my $id1 = $sim->id1;
	my $id2 = $sim->id2;
	my $sc = $sim->psc;
	if ($in{$id1} && $in{$id2} && ($in{$id1} != $in{$id2}))
	    my $key = join("\t",($in{$id1},$in{$id2}));
	    if ((! ($sofar = $best{$key})) || ($sofar > $sc))
		$best{$key} = $sc;
	    $key = join("\t",($in{$id2},$in{$id1}));
		$best{$key} = $sc;
    my @distances = ();
    foreach my $key (keys(%best))
	my($n1,$n2) = split(/\t/,$key);
	push(@distances,[$n1,$n2,$best{$key}]);
    return sort { ($a->[0] <=> $b->[0]) or ($a->[1] <=> $b->[1]) } @distances;
