[Bio] / FigKernelScripts / split_clean_unclean_families.pl Repository:
Log of /FigKernelScripts/split_clean_unclean_families.pl
Wed Apr 12 14:23:10 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.3: +15 -13 lines
fixes for splitting families into clean/unclean
Wed Apr 12 14:13:26 2006 UTC (13 years, 9 months ago) by overbeek
Changes since 1.2: +7 -4 lines
Wed Apr 12 13:10:38 2006 UTC (13 years, 9 months ago) by overbeek
fixes to making assignments based on consistency
Fri Mar 31 19:37:40 2006 UTC (13 years, 9 months ago) by overbeek
Diff to selected 1.2
next version of the STAG code
