[Bio] / FigKernelScripts / split_and_install_pchs.pl Repository:
View of /FigKernelScripts/split_and_install_pchs.pl
Revision 1.2 - (download) (as text) (annotate)
Mon Dec 5 18:56:38 2005 UTC (14 years, 3 months ago) by olson
CVS Tags: mgrast_dev_08112011, rast_rel_2009_05_18, mgrast_dev_08022011, rast_rel_2014_0912, rast_rel_2008_06_18, myrast_rel40, rast_rel_2008_06_16, mgrast_dev_05262011, rast_rel_2008_12_18, mgrast_dev_04082011, rast_rel_2008_07_21, rast_rel_2010_0928, rast_2008_0924, mgrast_version_3_2, mgrast_dev_12152011, rast_rel_2008_04_23, mgrast_dev_06072011, rast_rel_2008_09_30, rast_rel_2009_0925, rast_rel_2010_0526, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, caBIG-05Apr06-00, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2010_0118, mgrast_rel_2008_0924, mgrast_rel_2008_1110_v2, rast_rel_2009_02_05, rast_rel_2011_0119, mgrast_rel_2008_0625, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, rast_rel_2008_10_09, mgrast_dev_04012011, rast_release_2008_09_29, mgrast_rel_2008_0806, mgrast_rel_2008_0923, mgrast_rel_2008_0919, rast_rel_2009_07_09, rast_rel_2010_0827, mgrast_rel_2008_1110, myrast_33, rast_rel_2011_0928, rast_rel_2008_09_29, mgrast_rel_2008_0917, rast_rel_2008_10_29, mgrast_dev_04052011, mgrast_dev_02222011, caBIG-13Feb06-00, rast_rel_2009_03_26, mgrast_dev_10262011, rast_rel_2008_11_24, rast_rel_2008_08_07, HEAD
# Public License.
# Given a stream of computed PCH data on stdin (the output of
# a remove_clustered_pchs | compute_simple_scores pipeline),
# append the data to the files in FIG_Config::data/CouplingData/PCHs/<genome>.
use FIG_Config;
use FileHandle;
my $usage = "split_and_install_pchs < pch-data";
my $pch_dir = "$FIG_Config::data/CouplingData/PCHs";
-d $pch_dir or die "PCH directory $pch_dir does not exist\n";
my %genome_fhs;
while (<>)
    if (/^fig\|(\d+\.\d+)\.peg/)
	write_line($1, $_);
for my $fh (values(%genome_fhs))
    close($fh);
sub write_line
    my($genome, $line) = @_;
    my $fh = $genome_fhs{$genome};
    if (!defined($fh))
	$fh = new FileHandle(">>$pch_dir/$genome");
	if (!$fh)
	    die "Cannot open $pch_dir/$genome for append: $!";
	$genome_fhs{$genome} = $fh;
    print $fh $line;
