[Bio] / FigKernelScripts / sphinx_index_genome.pl Repository:
Log of /FigKernelScripts/sphinx_index_genome.pl
Links to mgrast_dev_03312011: (view) (download) (as text) (annotate)
Mon Feb 14 22:47:40 2011 UTC (9 years, 3 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.6: +32 -2 lines
More fixups.
Mon Jun 7 21:25:47 2010 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.5: +19 -9 lines
speed up alias computation
Mon Jun 7 20:55:01 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.4: +19 -9 lines
more indexing fixes
Mon Jun 7 18:47:41 2010 UTC (9 years, 11 months ago) by olson
more fixes
Mon Jun 7 18:35:58 2010 UTC (9 years, 11 months ago) by olson
remove undef warnings
Mon Jun 7 18:30:01 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.1: +6 -1 lines
add subsystems present to index
Mon Jun 7 18:20:23 2010 UTC (9 years, 11 months ago) by olson
sphinx genome indexer
