[Bio] / FigKernelScripts / sphinx_index_genome.pl Repository:
Log of /FigKernelScripts/sphinx_index_genome.pl
Wed Jan 27 19:21:51 2016 UTC (4 years, 4 months ago) by olson
CVS Tags: HEAD
Changes since 1.13: +10 -0 lines
fix indexing bug with unanticipated feature types.
Fri Jan 22 21:07:23 2016 UTC (4 years, 4 months ago) by olson
Fix bad tag
Fri Jan 22 20:47:27 2016 UTC (4 years, 4 months ago) by olson
Changes since 1.11: +18 -2 lines
add roles to subsystem index
Fri Jul 19 19:27:27 2013 UTC (6 years, 10 months ago) by olson
CVS Tags: rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.10: +101 -1 lines
add support for dlit indexing
Fri Jul 29 18:04:42 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Index incomplete orgs as well
Wed May 18 18:49:26 2011 UTC (9 years ago) by olson
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_1_0, myrast_rel40
Changes since 1.8: +5 -1 lines
index contig ids with genomes
Sat May 7 23:27:39 2011 UTC (9 years ago) by olson
Changes since 1.7: +162 -62 lines
Doh. Check in the latest indexer, things will be happier then.
Mon Feb 14 22:47:40 2011 UTC (9 years, 3 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.6: +32 -2 lines
More fixups.
Mon Jun 7 21:25:47 2010 UTC (9 years, 11 months ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.5: +19 -9 lines
speed up alias computation
Mon Jun 7 20:55:01 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.4: +19 -9 lines
more indexing fixes
Mon Jun 7 18:47:41 2010 UTC (9 years, 11 months ago) by olson
more fixes
Mon Jun 7 18:35:58 2010 UTC (9 years, 11 months ago) by olson
remove undef warnings
Mon Jun 7 18:30:01 2010 UTC (9 years, 11 months ago) by olson
Changes since 1.1: +6 -1 lines
add subsystems present to index
Mon Jun 7 18:20:23 2010 UTC (9 years, 11 months ago) by olson
sphinx genome indexer
