[Bio] / FigKernelScripts / sphinx_index_genome.pl Repository:
Log of /FigKernelScripts/sphinx_index_genome.pl
Fri Jul 29 18:04:42 2011 UTC (8 years, 10 months ago) by olson
CVS Tags: mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, rast_rel_2011_0928
Index incomplete orgs as well
Revision 1.9 - (view) (download) (as text) (annotate) - [selected]
Wed May 18 18:49:26 2011 UTC (9 years ago) by olson
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_release_3_1_0, myrast_rel40
Changes since 1.8: +5 -1 lines
index contig ids with genomes
Sat May 7 23:27:39 2011 UTC (9 years, 1 month ago) by olson
Changes since 1.7: +162 -62 lines
Diff to previous 1.7 , to selected 1.9
Doh. Check in the latest indexer, things will be happier then.
Mon Feb 14 22:47:40 2011 UTC (9 years, 3 months ago) by olson
CVS Tags: mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, myrast_33
Changes since 1.6: +32 -2 lines
Diff to previous 1.6 , to selected 1.9
More fixups.
Mon Jun 7 21:25:47 2010 UTC (10 years ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.5: +19 -9 lines
Diff to previous 1.5 , to selected 1.9
speed up alias computation
Mon Jun 7 20:55:01 2010 UTC (10 years ago) by olson
Changes since 1.4: +19 -9 lines
Diff to previous 1.4 , to selected 1.9
more indexing fixes
Mon Jun 7 18:47:41 2010 UTC (10 years ago) by olson
Diff to previous 1.3 , to selected 1.9
more fixes
Mon Jun 7 18:35:58 2010 UTC (10 years ago) by olson
Diff to previous 1.2 , to selected 1.9
remove undef warnings
Mon Jun 7 18:30:01 2010 UTC (10 years ago) by olson
Changes since 1.1: +6 -1 lines
Diff to previous 1.1 , to selected 1.9
add subsystems present to index
Mon Jun 7 18:20:23 2010 UTC (10 years ago) by olson
Diff to selected 1.9
sphinx genome indexer
