[Bio] / FigKernelScripts / sphinx_index_genome.pl Repository:
Log of /FigKernelScripts/sphinx_index_genome.pl
Mon Jun 7 21:25:47 2010 UTC (10 years ago) by olson
CVS Tags: rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119
Changes since 1.5: +19 -9 lines
speed up alias computation
Mon Jun 7 20:55:01 2010 UTC (10 years ago) by olson
Changes since 1.4: +19 -9 lines
more indexing fixes
Mon Jun 7 18:47:41 2010 UTC (10 years ago) by olson
more fixes
Mon Jun 7 18:35:58 2010 UTC (10 years ago) by olson
remove undef warnings
Mon Jun 7 18:30:01 2010 UTC (10 years ago) by olson
Changes since 1.1: +6 -1 lines
add subsystems present to index
Mon Jun 7 18:20:23 2010 UTC (10 years ago) by olson
Diff to selected 1.3
sphinx genome indexer
