[Bio] / FigKernelScripts / sort_and_split_bbhs.pl Repository:
Log of /FigKernelScripts/sort_and_split_bbhs.pl
Links to mgrast_dev_04052011: (view) (download) (as text) (annotate)
Wed Sep 5 21:15:22 2007 UTC (12 years, 3 months ago) by olson
add $ENV{SORT_ARGS} to sort invocations for running on large-memory machines
Mon Dec 5 18:56:38 2005 UTC (14 years ago) by olson
Mon Sep 19 03:08:59 2005 UTC (14 years, 2 months ago) by overbeek
fixes in BBH generation
Mon Jun 13 16:43:57 2005 UTC (14 years, 5 months ago) by overbeek
Changes since 1.1: +0 -26 lines
Ross change commit after cleanup
Wed Jun 8 23:05:21 2005 UTC (14 years, 6 months ago) by overbeek
major change to BBHs (use precomputed)
