[Bio] / FigKernelScripts / sims_all.pl Repository:
Log of /FigKernelScripts/sims_all.pl
Wed Dec 17 16:19:51 2008 UTC (10 years, 11 months ago) by overbeek
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +4 -1 lines
remove paralogs before computing conections
Sun Apr 8 15:01:11 2007 UTC (12 years, 7 months ago) by overbeek
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_release_2008_09_29
Changes since 1.4: +7 -2 lines
Added '-no_redo_blast' switch. -- /gdp
Wed Jul 5 12:55:25 2006 UTC (13 years, 4 months ago) by overbeek
fix bug causing close strain sets to be screwed up
Thu Feb 16 13:11:36 2006 UTC (13 years, 9 months ago) by overbeek
handle deleted fids in mapped_prot_ids
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
Thu Apr 21 18:33:13 2005 UTC (14 years, 7 months ago) by overbeek
add computation of similarities - sims_all and sims_between - between close strains
