[Bio] / FigKernelScripts / similar_to.pl Repository:
Log of /FigKernelScripts/similar_to.pl
Links to mgrast_release_3_0_1: (view) (download) (as text) (annotate)
Mon Dec 5 18:56:38 2005 UTC (14 years, 5 months ago) by olson
Fri Aug 13 19:58:57 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.2: +3 -0 lines
add error stream for hits as tool runs in similar_to
Thu Aug 5 17:00:40 2004 UTC (15 years, 9 months ago) by overbeek
Changes since 1.1: +8 -6 lines
added upstream command
Mon May 31 23:03:40 2004 UTC (16 years ago) by overbeek
Diff to selected 1.3
fix to extract_genomes
