[Bio] / FigKernelScripts / server_paper_example7.pl Repository:
Log of /FigKernelScripts/server_paper_example7.pl
Tue Apr 27 04:05:03 2010 UTC (9 years, 6 months ago) by chenry
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.3: +8 -4 lines
Corrected a few bugs in the example script.
Wed Apr 21 22:06:59 2010 UTC (9 years, 7 months ago) by chenry
Changes since 1.2: +95 -26 lines
Created server paper example. Made minor changes to model driver. Corrected a bug in the scheduler.
Mon Jan 4 20:15:33 2010 UTC (9 years, 10 months ago) by disz
CVS Tags: rast_rel_2010_0118
Changes since 1.1: +4 -6 lines
Switched to ANNO server
Thu Oct 29 18:29:51 2009 UTC (10 years ago) by parrello
Final Server updates.
