[Bio] / FigKernelScripts / server_paper_example4.pl Repository:
Log of /FigKernelScripts/server_paper_example4.pl
Wed Mar 31 18:23:02 2010 UTC (10 years ago) by parrello
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.2: +2 -3 lines
Fixed to use the correct servers.
Fri Oct 23 19:16:20 2009 UTC (10 years, 5 months ago) by parrello
CVS Tags: rast_rel_2010_0118
Converted to use the SeedUtils::hypo method.
Wed Oct 21 18:17:16 2009 UTC (10 years, 5 months ago) by parrello
