[Bio] / FigKernelScripts / sequence_length_histogram.pl Repository:
Log of /FigKernelScripts/sequence_length_histogram.pl
Thu Oct 28 19:13:24 2010 UTC (9 years, 3 months ago) by olson
CVS Tags: HEAD, mgrast_dev_02212011, mgrast_dev_02222011, mgrast_dev_03252011, mgrast_dev_03312011, mgrast_dev_04012011, mgrast_dev_04052011, mgrast_dev_04082011, mgrast_dev_04132011, mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_0, mgrast_release_3_0_1, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_4, mgrast_release_3_1_0, mgrast_release_3_1_1, mgrast_release_3_1_2, mgrast_version_3_2, myrast_33, myrast_rel40, rast_rel_2010_1206, rast_rel_2011_0119, rast_rel_2011_0928, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.5: +4 -0 lines
Include in SAS
Thu Apr 29 19:15:00 2010 UTC (9 years, 9 months ago) by olson
CVS Tags: rast_rel_2010_0526, rast_rel_2010_0827, rast_rel_2010_0928
Changes since 1.4: +18 -8 lines
Additional fixes to new upload.
Wed Oct 10 20:48:03 2007 UTC (12 years, 4 months ago) by gdpusch
CVS Tags: mgrast_rel_2008_0625, mgrast_rel_2008_0806, mgrast_rel_2008_0917, mgrast_rel_2008_0919, mgrast_rel_2008_0923, mgrast_rel_2008_0924, mgrast_rel_2008_1110, mgrast_rel_2008_1110_v2, rast_2008_0924, rast_rel_2008_04_23, rast_rel_2008_06_16, rast_rel_2008_06_18, rast_rel_2008_07_21, rast_rel_2008_08_07, rast_rel_2008_09_29, rast_rel_2008_09_30, rast_rel_2008_10_09, rast_rel_2008_10_29, rast_rel_2008_11_24, rast_rel_2008_12_18, rast_rel_2009_02_05, rast_rel_2009_03_26, rast_rel_2009_05_18, rast_rel_2009_07_09, rast_rel_2009_0925, rast_rel_2010_0118, rast_release_2008_09_29
Changes since 1.3: +88 -38 lines
Rewrote counting of DNA characters (-get_dna option). -- /gdp
Wed Jun 13 20:34:03 2007 UTC (12 years, 8 months ago) by gdpusch
Added support for RNA character "U". -- /gdp
Thu Oct 19 20:03:37 2006 UTC (13 years, 4 months ago) by overbeek
Fixed bug in usage-msg. -- /gdp
Thu Jun 1 22:16:48 2006 UTC (13 years, 8 months ago) by overbeek
Initial checkin. -- /gdp
