[Bio] / FigKernelScripts / seed2tbl.pl Repository:
View of /FigKernelScripts/seed2tbl.pl
Revision 1.3 - (download) (as text) (annotate)
Thu Nov 11 17:27:39 2010 UTC (9 years, 8 months ago) by disz
CVS Tags: mgrast_dev_08112011, mgrast_dev_08022011, rast_rel_2014_0912, myrast_rel40, mgrast_dev_05262011, mgrast_dev_04082011, mgrast_version_3_2, mgrast_dev_12152011, mgrast_dev_06072011, rast_rel_2014_0729, mgrast_dev_02212011, rast_rel_2010_1206, mgrast_release_3_0, mgrast_dev_03252011, rast_rel_2011_0119, mgrast_release_3_0_4, mgrast_release_3_0_2, mgrast_release_3_0_3, mgrast_release_3_0_1, mgrast_dev_03312011, mgrast_release_3_1_2, mgrast_release_3_1_1, mgrast_release_3_1_0, mgrast_dev_04132011, mgrast_dev_04012011, myrast_33, rast_rel_2011_0928, mgrast_dev_04052011, mgrast_dev_02222011, mgrast_dev_10262011, HEAD
FigFam 6 digit problem
#!/usr/bin/env perl
use Getopt::Std;
use strict;
use warnings;
use Data::Dumper;
use FIGV;
use Carp;
our ( $opt_o, $opt_s, $opt_l, $opt_p, $opt_i, $opt_r, $opt_e, $opt_x, $opt_a );
getopts( 'o:s:l:p:i:r:e:x:a:' );
#my %preimages_of;
my %images_of;
# view the inputs #
#*    org_dir    *#
my $org_dir = $opt_o;
if ( !( -d $org_dir) ) {
  &usage;
  die "No orgdir $org_dir\n";
my $fig = FIGV->new($org_dir);
#* submitter id  *#
my $submitter_ID = $opt_s;
if ( !defined( $submitter_ID ) ) {
  &usage;
  die "No submitter ID given\n";
#* pseudo genes  *#
my $pseudo_list;
if ( defined( $opt_p ) ) {
  $pseudo_list = load_pseudo_list( $opt_p );
#* partial genes  *#
my $partial_list;
if ( defined( $opt_a ) ) {
  $partial_list = load_partial_list( $opt_a );
#* locus tag prefix *#
my $locus_tag_prefix = $opt_l;
if ( !defined( $locus_tag_prefix ) ) {
  &usage;
  die "No locus tag prefix given\n";
#* prot ID prefix *#
my $prot_ID_prefix = $opt_i;
if ( !defined( $prot_ID_prefix ) ) {
  $prot_ID_prefix = $locus_tag_prefix;
#* bad ECs file *#
my $bad_ECs_file = $opt_e;
if ( !defined( $bad_ECs_file ) ) {
  $bad_ECs_file = 'ECs_deleted_and_transferred.txt';
#* results file *#
my $res_file = $opt_r;
if ( !defined( $res_file ) ) {
  &usage;
  die "No output file given\n";
#* xls file *#
my $xls_log_file = $opt_x;
if ( !defined( $xls_log_file ) ) {
  $xls_log_file = $res_file;
  $xls_log_file =~ s/\.tbl/\.xls/;
open ( RES, ">$res_file" ) or die "can't open $res_file!\n";
open ( XLS_LOG, qq(>$xls_log_file)) || die qq(Could not write-open $xls_log_file);
# load hashes for keep caps and special cases #
my $keep_caps     = &load_keep_caps;
my $special_cases = &load_special_cases();
my $map_EC_to = &load_bad_EC_numbers( $bad_ECs_file );
# Some Constants #
use constant ENTRY  =>  0;
use constant FILE   =>  1;
use constant FID    =>  2;
use constant LOCUS  =>  3;
use constant CONTIG =>  4;
use constant START  =>  5;
use constant STOP   =>  6;
use constant LEN    =>  7;
use constant STRAND =>  8;
use constant FUNC   =>  9;
# load sequences for the genome #
my $contigs_file = "$org_dir/contigs";
my ($seq_of, $len_of) = &load_contigs($contigs_file);
# load tbl files #
my @tbl_files;
my $tmp = "$org_dir/Features/rna/tbl";
if (-s $tmp) { push @tbl_files, $tmp; } else { push @tbl_files, "/dev/null"; }
$tmp = "$org_dir/Features/peg/tbl";
if (-s $tmp) { push @tbl_files, $tmp; } else { die "PEG tbl file $tmp does not exist"; }
my $tbl = &load_tbls(@tbl_files);
# load functions #
my %func_of = map { chomp; m/^(\S+)\t(.*)$/o ? ($1 => $2) : () } `cat $org_dir/assigned_functions`;
# Now start the process - go through contigs #
my $done_fids;
foreach my $contig_id (sort keys %$seq_of) {
  print RES ">Feature\t$contig_id\n";
  my $contig_features = $tbl->{ $contig_id };
  foreach my $entry ( @$contig_features ) {
    # this was put in for pseudogenes, where the second/following
    # part is already part of the pseudogene
    next if $done_fids->{ $entry->[FID] };
    # get entry type
    my $type = &type_of( $entry );
    if ( !defined( $type ) ) {
      die ( qq(aborting with entry = ), $fig->flatten_dumper($entry), qq(\n), Dumper( $contig_features ) );
    # get entry function
    $entry->[FUNC] = $func_of{ $entry->[FID] };
    # get the feature number
    my $feature_number;
    if ( $entry->[FID] =~ m/\.(\d+)$/ ) {
      $feature_number = $1;
    else {
      die "Could not parse FID $entry->[FID]";
    if ( defined( $pseudo_list->{ $entry->[FID] } ) ) {
      &output_PSEUDO( $entry, $feature_number, $locus_tag_prefix, *RES, $pseudo_list->{ $entry->[FID] }, $done_fids, $contig_features );
      next;
    if ( $type eq qq(CDS) ) {
      &output_CDS( $entry, $feature_number, $locus_tag_prefix, $partial_list, *RES, *XLS_LOG );
    elsif ( $type =~ m/RNA/o ) {
      &output_RNA( $entry, $feature_number, $locus_tag_prefix, *RES );
    else {
      die "Unsupported feature type:\n", Dumper($entry);
# close up stuff #
close RES;
close XLS_LOG;
## METHODS ##
# Write PSEUDOS #
sub output_PSEUDO {
  my ( $entry, $feature_number, $locus_tag_prefix, $RES, $otherones, $donehash, $contig_features ) = @_;
  $feature_number = &zero_pad( 6, $feature_number );
  my $locus_tag = $locus_tag_prefix . $feature_number;
  my $strand = 'fw';
  my ( $nonsense, $beg, $end ) = $fig->boundaries_of( $entry->[LOCUS] );
  if ( $beg > $end ) {
    $strand = 'rv';
  $donehash->{ $entry->[FID] } = 1;
  foreach my $oo ( @$otherones ) {
    my $thisentry;
    foreach my $te ( @$contig_features ) {
      if ( $te->[FID] eq $oo ) {
	my ($beg1, $end1);
	(undef, $beg1, $end1) = $fig->boundaries_of( $te->[LOCUS] );
	if ( $strand eq 'fw' ) {
	  $end = $end1;
	else {
	  $beg = $beg1;
    $donehash->{ $oo } = 1;
  my $func  = $entry->[FUNC];
  $func =~ s/\s+/ /go;
  my ($product, $prot_desc, $notesP, $ec_numsP, $tc_numsP, $famsP) = &normalize_function( $entry->[FID], $func, 0);
  if ( !defined( $product ) || $product eq '' ) {
    $product = $prot_desc;
  if ( $product =~ /(.*)\s\# frameshift$/ ) {
    $product = $1;
  print $RES (join(qq(\t), ($beg, $end, 'gene')),                       qq(\n));
  print $RES join(qq(\t), (qq(), qq(), qq(), qq(gene_desc),    $product)),    qq(\n);
  print $RES (join(qq(\t), (qq(),        qq(),        qq(),       qq(locus_tag),  $locus_tag)),  qq(\n));
  print $RES (join(qq(\t), (qq(),        qq(),        qq(),       qq(pseudo)),  qq(\n)));
  print $RES (join(qq(\t), (qq(),        qq(),        qq(),       qq(note), qq(frameshift)),  qq(\n)));
# Write RNAs #
sub output_RNA {
  my ( $entry, $feature_number, $locus_tag_prefix, $RES ) = @_;
  $feature_number = &zero_pad( 6, $feature_number, qq(rna) );
  my ( $nonsense, $beg, $end ) = $fig->boundaries_of($entry->[LOCUS]);
  print $RES ( join( qq(\t), ($beg, $end, qq(gene))), qq(\n),
	       join( qq(\t), (qq(),        qq(),        qq(),       qq(locus_tag),  $locus_tag)),  qq(\n),
  my $trunc = $fig->possibly_truncated( $entry->[FID] );
  if ($beg < $end) {
    if ( $trunc eq qq(start) ) {
      $beg = qq(<$beg);
    elsif ( $trunc eq qq(stop) ) {
      $end = qq(>$end);
  else {
      $beg = qq(>$beg);
      $end = qq(<$end);
  my $type = &type_of($entry);
  if    ($func =~ m/5S\s*RNA/o) {
    #...No change
    $func = qq(5S rRNA);
  elsif ($func =~ m/SSU\s*rRNA/o) {
    $func = qq(16S rRNA);
  elsif ($func =~ m/LSU\s*rRNA/o) {
	$func = qq(23S rRNA);
  elsif ($func =~ m/^tRNA/o) {
    # try to cut off the codon (anticodon?) information
    if ( $func =~ /^(tRNA-\w{3}).*/ ) {
      $func = $1;
  else {
    $func = qq(misc_RNA);
  print $RES (join(qq(\t), ($beg, $end, $type)),                       qq(\n));
  print $RES (join(qq(\t), (qq(), qq(), qq(),    qq(product), $func)), qq(\n));
  return 1;
# Write CDSs #
sub output_CDS {
  my ( $entry, $feature_number, $locus_tag_prefix, $partial_list, $RES, $XLS_LOG ) = @_;
  my $fid = $entry->[FID];
  # get entry location on the contig
  my ( $nonsense, $region_beg, $region_end ) = $fig->boundaries_of( $entry->[LOCUS] );
  if ( defined( $partial_list->{ $fid } ) ) {
    my ( $st, $val ) = @{ $partial_list->{ $fid } };
    if ( $st eq 'start' ) {
      $region_beg = $val;
    if ( $st eq 'stop' ) {
      $region_end = $val;
  print $RES ( join( qq(\t), ($region_beg, $region_end, qq(gene))), qq(\n),
  my @products   = ();
  my @prot_descs = ();
  my @notes       = ();
  my @ec_nums     = ();
  my @tc_nums     = ();
  my @fams        = ();
  # Write locus information #
  my @chunks = split( m/,/, $entry->[LOCUS] );
  my $first_chunk = shift @chunks;
  my ( $nonsense2, $beg, $end ) = $fig->boundaries_of( $first_chunk );
      $beg = $val;
      $end = $val;
  print $RES ( join( qq(\t), ( $beg, $end, qq(CDS) ) ), qq(\n) );
  foreach my $chunk (@chunks) {
    ( undef, $beg, $end ) = $fig->boundaries_of( $chunk );
    print $RES ( join( qq(\t), ($beg, $end) ), qq(\n) );
  # Now about the CDS function #
  my $original_func = $func;
  # Trim off "comment" field; save it as a "note" if it "propagates"
  if ( $func =~ m/(\#{1,2})\s+(.*)$/ ) {
    if ( $1 eq qq(\#\#) ) {
      push @notes, $2;
    $func =~ s/\#.*$//o;
  # Check type of assignment
  my $assignment_type = q();
  if    ($func =~ m{ \/ }) {
    $assignment_type = qq(multifunctional enzyme);
  elsif ($func =~ m{\@ }) {
    $assignment_type = qq(enzyme with broad specificity);
  elsif ($func =~ m{\; }) {
    $assignment_type = qq(most likely function alternative not yet resolved);
  #...Split on " / ", '; ', or " @ "
  my @funcs = split m{ \/ |\; | \@ }, $func;
  my @tmp = @funcs;
  @tmp = grep { &weasel_words($_) } map { s{ [\(\[] [ET] C [^\)\]]+ [\)\]] }{}gox; $_ } @tmp;
  # Now go through functions #
  foreach $func ( @funcs ) {
    my $prenormalized_func = $func;
    my $x;
    if ( defined( $x = $special_cases->{$original_func} ) ) {
      if ( defined( $x->{ prod } ) ) {
	push ( @products, @{ $x->{ prod } } );
      if ( defined( $x->{ desc } ) ) {
	push ( @prot_descs, @{ $x->{ desc } } );
      if ( defined( $x->{ note } ) ) {
	push ( @notes, @{ $x->{ note } } );
      if ( defined( $x->{ ecnu } ) ) {
	push ( @ec_nums, @{ $x->{ ecnu } } );
      last;
    elsif ( defined( $x = $special_cases->{$func} ) ) {
    else {
      my ( $product, $prot_desc, $notesP, $ec_numsP, $tc_numsP, $famsP ) = &normalize_function( $fid, $func );
      push (@products,   $product)    if $product;
      push (@prot_descs, $prot_desc)  if $prot_desc;
      push (@notes,      @$notesP);
      push (@ec_nums,    @$ec_numsP);
      push (@tc_nums,    @$tc_numsP);
      push (@fams,       @$famsP);
      #...Add note for PEGs marked "(fragment)," and set "pseudogene" flag as required by NCBI
      if ($func =~ /fragment/io) {
	unshift @notes, qq(Fragment);
	$func =~ s/\s*\(?fragment\)?//i;
#    if ( !defined( $notesP ) )  {
#      $notesP = [];
#    if ($product) {
#      if (not defined($preimages_of{$product}))    { $preimages_of{$product} = {}; }
#      $preimages_of{$product}->{$func}   = [ qq(prod), @$notesP ];
#    if ($prot_desc) {
#      if (not defined($preimages_of{$prot_desc}))  { $preimages_of{$prot_desc} = {}; }
#      $preimages_of{$prot_desc}->{$func} = [ qq(desc), @$notesP ];
  if ( $assignment_type ) {
    if ( $assignment_type eq qq(multifunctional enzyme) ) {
      if ( @products ) {
	my $product = join( qq(/), @products );
	@products = ( $product );
      else {
	unshift @notes, $assignment_type;
    else {
  if ( @products == 0 ) {
    push @products, qq(hypothetical protein);
  @products = @{ uniquify( \@products ) };
  foreach my $product   (@products) {
    print $RES join(qq(\t), (qq(), qq(), qq(), qq(product),    $product)),    qq(\n);
  @prot_descs = @{ uniquify( \@prot_descs ) };
  foreach my $prot_desc ( @prot_descs ) {
    print $RES join(qq(\t), (qq(), qq(), qq(), qq(prot_desc),  $prot_desc)),  qq(\n);
  @ec_nums = @{ uniquify( \@ec_nums ) };
  foreach  my $ec_num ( @ec_nums ) {
    print $RES join(qq(\t), (qq(), qq(), qq(), qq(EC_number),  $ec_num)),     qq(\n);
  my @notestmp = @tc_nums;
  push @notestmp, @fams;
  push @notestmp, @notes;
  @notes = @{ uniquify( \@notestmp ) };
  foreach my $note ( @notes ) {
    print $RES join(qq(\t), (qq(), qq(), qq(), qq(note),       $note)),  qq(\n);
  @tmp = ();
  push @tmp, map { qq(prod: $_) } @products;
  push @tmp, map { qq(desc: $_) } @prot_descs;
  push @tmp, map { qq(note: $_) } @notes;
  my $first_annot = shift(@tmp) || qq();
  print $XLS_LOG (join(qq(\t), ($fid, $original_func, $first_annot, join(qq( ), @ec_nums))), qq(\n));
  foreach my $tmp (@tmp) {
    print $XLS_LOG (join(qq(\t), (q(), q(), qq(), $tmp, qq())), qq(\n));
  my $fid_num = 0;
  if ( $fid =~ m/\.(\d+)$/ ) {
    $fid_num = $1;
    $fid_num = ( "0" x ( 6 - length( $fid_num ) ) ) . $fid_num;
  else {
  # print the protein id #
  print $RES (join(qq(\t), (qq(), qq(), qq(), qq(protein_id), qq(gnl\|$submitter_ID\|$prot_ID_prefix).$fid_num)),  qq(\n));
  return 1;
# constructs the protein id #
sub zero_pad {
    my ($num_digits, $number, $prefix) = @_;
    $prefix = defined($prefix) ? $prefix : qq();
    my $prefix_length = length($prefix);
    my $number_length = length($number);
    if ($num_digits < $prefix_length + $number_length) {
	die "!!! Too many digits: digits=$num_digits, number=$number, prefix=$prefix";
    return ($prefix . ("0" x ($num_digits - $prefix_length - $number_length)) . $number);
# through double entries away #
sub uniquify {
  my ( $array ) = @_;
  my @retarray;
  my %used;
  foreach ( @$array ) {
    next if ( defined( $used{ $_ } ) );
    $used{ $_ } = 1;
    push @retarray, $_;
  return \@retarray;
sub type_of {
    my ($entry) = @_;
    my $func = $entry->[FUNC] || qq();
    if    ($fid =~ m/\.peg\./o) {
	return qq(CDS);
    elsif ($fid =~ m/\.rna\./o) {
	if (($func =~ m/rRNA/o) || ($func =~ m/5S RNA/o)) {
	    return qq(rRNA);
	elsif ($func =~ m/tRNA/o) {
	    return qq(tRNA);
	else {
	    return qq(misc_RNA);
    else {
	die "This Can't Happen !!!";
sub weasel_words {
#...Attempt to catch things NCBI bitches about in protein names
    my ($x) = @_;
#...protein names should not contain molecular weights
#    if ($x =~ /\bkDa\b/io)                 { return 1 }
#...fragments are not "real" genes, but are demoted to "pseudogenes"
#    if ($x =~ /fragment/io)                { return 2 }
#...protein names should not mention cellular location
#    if ($x =~ /inner[- ]membrane/io)       { return 3 }
#    if ($x =~ /periplasmic/io)             { return 4 }
#...protein names should not contain any hint of ambiguity
#    if ($x =~ /predicted/io)               { return 5 }
#    if ($x =~ /probable/io)                { return 6 }
#    if ($x =~ /putative/io)                { return 7 }
#    if ($x =~ /hypothetical/io)            { return 8 }
#...protein names should not be descriptive phrases
    if ($x =~ /,\s/io)                     { return 9 }
#    if ($x =~ /\sand\s/io)                 { return 10 }
#    if ($x =~ /of\s+the\b.*\b(super)?family/io)         { return 100 }
#    if ($x =~ /fused\s+to/io)              { return 11 }
#    if ($x =~ /involved\s+in/io)           { return 12 }
#    if ($x =~ /component.*\bof\b/io)       { return 13 }
#    if ($x =~ /exported\s+protein/io)      { return 14 }
#...protein names should not contain references to homology
#    if ($x =~ /motif/io)                   { return 15 }
#    if ($x =~ /containing/io)              { return 16 }
#    if ($x =~ /analog\s+of/io)             { return 17 }
#    if ($x =~ /[- ]like/io)                { return 18 }
#    if ($x =~ /similar\s+to/io)              { return 19 }
#    if ($x =~ /similarity/io)              { return 20 }
#    if ($x =~ /homolog(ous)?/io)           { return 21 }
#    if ($x =~ /ortholog(ous)?/io)          { return 22 }
#    if ($x =~ /structural\s+feature/io)    { return 23 }
#    if ($x =~ /conserved.*\bdomain\b/io)   { return 24 }
#    if ($x =~ /conserved\s+in/io)          { return 25 }
#    if ($x =~ /binding[- ]site/io)         { return 26 }
    return 0;
sub normalize_function {
    my ($fid, $func) = @_;
    my $product   = qq();
    my $prot_desc = qq();
    my $notesP    = [];
    my $ec_numsP  = [];
    my $tc_numsP  = [];
    my $famsP     = [];
    #...Trim leading and trailing spaces, and collapse multiple spaces
    $func =~s/^\s+//o;
    $func =~s/\s+$//o;
    $func =~s/\s+/ /go;
    #...Remove whitespace before commas
    $func =~ s/\s+,/,/go;
    #...Remove space between ")" and "-"
    $func =~ s/\)\s+\-/\)\-/go;
    #...Remove references to FIGfam membership
    if ($func =~ m/^(FIG\d+)/) {
	#...We are currently suppressing FIGfam-IDs
	$func =~ s/^FIG\d+[:_ ]\s*//o;
	$func =~ s/^FIG\d+\s+\(not\s+subsystem\s+based\):\s+//o;
    #...Move references to EC-numbers into @$ec_numsP
#   print STDERR qq($fid\t$func\n);
    while ($func =~ m/[\(\]]\s*EC[_:]?\s*([^\)\]]+)[\)\]]/o) {
	my $contents = $1;
#	print STDERR qq(\t$contents:);
	foreach my $token (split(m/[, ]\s*/, $contents)) {
	    if ($token =~ m/(\d+\.([0-9]+|-)\.([0-9]+|-)\.([0-9]+|-))/o) {
		my $ec_num = $1;
#		print STDERR qq(\t$ec_num);
		if    ($ec_num =~ m/\.\-$/o) {
		    #...Skip partials
		    next;
		elsif (defined($map_EC_to->{$ec_num})) {
		    #...Skip any changed EC
		    next;
# 		    if ($map_EC_to->{$ec_num} eq qq(-1)) {
# 			#...Skip --- EC is either split or deleted
# 			next;
# 		    else{
# 			#...Replace EC if uniquely mappable
# 			$ec_num = $map_EC_to->{$ec_num};
		push @$ec_numsP, $ec_num;
	    else {
		push @$notesP, $token;
	$func =~ s/[\(\]]\s*EC[_:]?\s*([^\)\]]+)[\)\]]//o;
    #...Move references to TC-numbers into @$tc_numsP
    if ($func =~ m/\(\s*TC[_:]?\s*([^\)]+)\)/o) {
	push @$tc_numsP, qq(TC $1);
	$func =~ s/\(\s*TC[^\)]+\)//;
    #...Move references to COGs into @fams (will become "note")
    $func =~ s/^COGs\s*//o;
    if ($func =~ m/COG/) {
	if ($func =~ s/^((COG\d{4})[,:_]?\*(family)?)\s*/$2 $3/o) {
	    push @$notesP, $func;
	    $func = qq();
	else {
	    while ($func =~ s/,?\s*(COG\d{4}):?\s*//o) {
		push @$famsP, $1;
    #...Again trim leading and trailing spaces, collapse multiple spaces, and snug up commas
    $func =~s/^\s*,?\s+//o;
    $func =~s/\s+$//o;
    $func =~s/\s+/ /go;
    #...Attempt to downcase "ALL CAPS"
    if ($func !~ m/[a-z]/) {
	$func = lc($func);
    #...If first word is capitalized, and not on list of known gene-names,
    #   downcase initial cap
    if ($func =~ m/^(\w+)/) {
	my $first_token = $1;
	if (($first_token =~ m/^[A-Z][a-z]+$/o) && (not $keep_caps->{$first_token})) {
	    substr($func, 0, 1) = lc( substr($func, 0, 1) );
    if ( my $code = weasel_words( $func ) ) {
      if ( $code == 9 ) {
	my $newfunc = transform($func, $special_cases, $keep_caps);
	$func = join( "/", @{ $newfunc->{prod} });
	$product = $func;
	if (my $code = weasel_words($func)) {
#	  print STDERR "AGAIN: $code $func\n";
      else {
	$prot_desc = $func;
    else {
      $product   = $func;
    return ($product, $prot_desc, $notesP, $ec_numsP, $tc_numsP, $famsP);
# load contigs #
sub load_contigs
    my ($contigs_file) = @_;
    my $seq_of = {};
    my $len_of = {};
    open (CONTIGS, "<$contigs_file") or die "could not open $contigs_file to read";
    while ( (! eof(CONTIGS)) && ( my ($id, $seqP) = &FIG::read_fasta_record(\*CONTIGS) ) )
    	$$seqP =~ tr/a-z/A-Z/;
	$seq_of->{$id} = $$seqP;
	$len_of->{$id} = length($$seqP);
    close(CONTIGS) or die "could not close $contigs_file";
    return ($seq_of, $len_of);
# load tbl files #
sub load_tbls
    my (@tbl_files) = @_;
    my ($entry, $fid, $org, $locus, $contig, $beg, $end, $strand, $len);
    my $tbl  = {};
    my $file = 0;
    foreach my $tbl_file (@tbl_files)
	my $num_fids = 0;
	open(TBL,"<$tbl_file") || die "could not open $tbl_file";
	print STDERR "Loading $tbl_file ...\n" if $ENV{VERBOSE};
	while (defined($entry = <TBL>))
	    ++$num_fids;
	    chomp $entry;
	    if ($entry =~ /^(\S+)\s+(\S+)/)
		($fid, $locus) = ($1, $2);
		if ($fid =~ m/^fig\|(\d+\.\d+)/) { $org = $1; } else { die "Invalid FID $fid"; }
		($contig, $beg, $end) = $fig->boundaries_of($locus);
		if ($beg < $end) { $strand = '+'; } else { $strand = '-'; }
		$len = 1 + abs($end-$beg);
		unless (defined($tbl->{$contig})) { $tbl->{$contig} = []; }
		push(@ { $tbl->{$contig} }
		     , [$entry, $file, $fid, $locus, $contig, $beg, $end, $len, $strand]
	    else
		print STDERR "Skipping invalid entry $entry\n";
	print STDERR "Loaded $num_fids features from $tbl_file\n\n" if $ENV{VERBOSE};
	close(TBL);
	++$file;
    foreach my $contig (keys(%$tbl))
	my $x = $tbl->{$contig};
	$tbl->{$contig} = [sort { &FIG::min($a->[START],$a->[STOP]) <=> &FIG::min($b->[START],$b->[STOP]) } @$x];
    return $tbl;
# Names that should stay caps #
sub load_keep_caps {
  my $keep_caps = {};
  my $entry;
  while ( defined( $entry = <DATA> ) ) {
    last if ( $entry eq qq(///\n) );
    chomp $entry;
    $keep_caps->{ $entry } = 1;
  return $keep_caps;
# list of pseudogenes #
sub load_pseudo_list {
  my ( $pseudo_file ) = @_;
  my $pseudo_list;
  open ( PL, $pseudo_file ) or die "cannot open $pseudo_file";
  while ( <PL> ) {
    chomp;
    next if ( !defined( $_ ) );
    my @frags = split( "\t", $_ );
    my $first = shift @frags;
    $pseudo_list->{ $first } = \@frags;
  close PL;
  return $pseudo_list;
# list of partial genes #
sub load_partial_list {
  my ( $partial_file ) = @_;
  my $partial_list;
  open ( PL, $partial_file ) or die "cannot open $partial_file";
  while ( <PL> ) {
    chomp;
    my ( $peg, $st, $val ) = split( "\t", $_ );
    $partial_list->{ $peg } = [ $st, $val ];
  close PL;
  return $partial_list;
# usage #
sub usage {
  print STDERR "seed2tbl -o ORGDIR
                         -s SUBMITTER_ID
                         -l LOCUS_TAG_PREFIX
                         -p PSEUDO_FILE
                         -i PROT_ID_PREFIX
                         -r RESULT_TBL_FILE
# bad EC numbers #
sub load_bad_EC_numbers {
    my ($bad_EC_file) = @_;
    open(BAD_ECs, qq(<$bad_EC_file))
	|| die qq(Could not read-open \`$bad_EC_file\');
    my $record;
    my $map_EC_to = {};
    while (defined($record = <BAD_ECs>)) {
	if ($record =~ m/^(\S+)/o) {
	    my $old_ec = $1;
	    if ($record =~ m/^\S+\t(\S+)/o) {
		my $new_ec = $1;
		if (not defined($map_EC_to->{$old_ec})) {
		    $map_EC_to->{$old_ec} = $new_ec;
		else {
		    #...Split EC
		    $map_EC_to->{$old_ec} = -1;
	    else {
		#...Deleted EC
	else {
	    die "Could not parse $bad_EC_file record $.: $record";
    close(BAD_ECs);
    return $map_EC_to;
# special cases #
sub load_special_cases {
  my $old_eol;
  my $special_cases = {};
  my $record;
  ($old_eol, $/) = ($/, qq(\n//\n));
  while ( defined( $record = <DATA> ) ) {
    chomp $record;
    my @entries = split( /\n/, $record );
    my $func = shift @entries;
    $func =~ s/^func:\t//o;
    my $x = $special_cases->{$func} = {};
    foreach my $entry ( @entries ) {
      my ( $type, $val ) = split( /\:\t/, $entry );
      push @ { $x->{$type} }, $val;
  $/ = $old_eol;
  return $special_cases;
sub transform {
    my ($func, $special, $keep_caps) = @_;
    $func =~ s/\s{2,10}/ /g;
#   $func =~ s/\) -methyl/)-methyl/g;
    if ((! $func) || ($func =~ m/^hypothetical\s*$/o)) {
	$func = "hypothetical protein";
    my $pieces = {};
    if ( $special->{ $func } ) {
      $func = $special->{ $func }
    if ( $func =~ /HASH/ ) {
      $func = join( '/', @{ $func->{ prod } } );
    my $func0 = &clean_comments($func);
    $func = $func0;
    my @funcs = split(/ \/ | \@ |\; /,$func);
    foreach my $x (@funcs)
	&transform1($x,$pieces,$special,$keep_caps);
    my %prods = map { $_ => 1 } @{$pieces->{prod}};
    $pieces->{prod} = [sort keys(%prods)];
    if (@funcs > 1) {
      $pieces->{prod} = [ join( "/", @{$pieces->{prod} } ) ];
    return $pieces;
sub transform1 {
    my($func, $pieces, $special, $keep_caps) = @_;
    my $note;
    if ($special->{$func}) { $func = $special->{$func} }
    my($func1,$ecs) = &clean_ecs($func);
    if (@$ecs > 0) { push(@{$pieces->{ecs}},@$ecs) }
    $func = $func1;
    my($func2,$tcs) = &clean_tcs($func);
    if (@$tcs > 0) { push(@{$pieces->{tcs}},@$tcs) }
    $func = $func2;
    #...NOTE: &clean_clustered_with() must be called before &clean_commas()
    my $func9;
    ($func9, $note) = &clean_clustered_with($func);
    if ($note) { push(@{$pieces->{notes}}, $note); }
    $func = $func9;
    my $func3 = &clean_commas($func);
    $func = $func3;
    my ($func8, $pseudo) = &clean_fragment($func);
    if ($pseudo) {
	#...This is klutzy, but I see no other work-around... :-(
	push @ { $pieces->{pseudo} }, qq(fragment);
    $func = $func8;
    my $func5 = &clean_cogs($func);
    $func = $func5;
    my($func6,$wts) = &clean_weights($func);
    $func = $func6;
    if (@$wts > 0) { push(@{$pieces->{notes}},@$wts) }
    my $func7 = &clean_rrna($func);
    $func = $func7;
    my($func4,$notes) = &clean_locations($func);
    $func = $func4;
    if (@$notes > 0) { push(@{$pieces->{notes}},@$notes) }
    my $func_final = &fix_caps($func, $keep_caps);
    $func = $func_final;
    if (not $func) { $func = qq(hypothetical protein); }
    push(@{$pieces->{prod}}, $func);
    return $pieces;
sub clean_clustered_with {
    #...NOTE: Must be called before &clean_commas()
    my ($func) = @_;
    my $note;
    if    ($func =~ s/\s*\((clustered\s+with\s+[^\)]+)\)//o) {
	$note = $1;
    elsif ($func =~ s/,?(\s+in)?\s+cluster(ed)?\s+(with.*)$//o) {
	$note = qq(clustered with $3);
    return ($func, $note);
sub fix_caps {
    my ($func, $keep_caps) = @_;
    if    (($func =~ m/^(\w+)/o) && (defined($keep_caps->{$1}))) {
	#...First token of $func is on the keep list; return unchanged
	return $func;
    elsif ($func !~ m/[a-z]/o) {
	#...Convert to lower-case, since NCBI hates "ALL CAPS"
	$func = lc( $func );
    else {
	#...Convert first letter to lower-case
	$func =~ s/^\s*//o;   #...Make sure first char is not "whitespace"
    return $func;
sub clean_fragment {
    my ($func) = @_;
    my $pseudo = qq();
    if ($func =~ s/\s*[\(]?fragment[\)]?//io) {
	$pseudo = 1;
    return ($func, $pseudo);
sub clean_rrna {
    my($func) = @_;
    $func =~ s/23s r?rna/LSU rRNA/i;
    $func =~ s/16s r?rna/SSU rRNA/i;
    return $func;
sub clean_weights {
    my($func) = @_;
    my $wts = [];
    if ($func =~ s/\b(\d+ kda)\s*//i)
	push(@$wts,$1);
    return ($func,$wts);
sub clean_cogs {
    my($func) = @_;
    $func =~ s/^COGs\s+//;
    $func =~ s/COG\d{4}[:,_]?\s*//;
    return $func;
sub clean_locations {
    my($func) = @_;
    my $notes = [];
    while ($func =~ s/\s*(outer membrane|inner membrane|cytoplasmic|periplasmic)( protein)?//i)
	push(@$notes, lc(qq($1 protein)));
    $func =~ s/^\s+//;
    return ($func,$notes);
sub clean_comments {
    my($func) = @_;
    $func =~ s/\s*\#.*$//;
    return $func;
# clean commas from the function #
sub clean_commas {
  my( $func ) = @_;
  # only if followed by space
  $func =~ s/, / /g;
  return $func;
# get EC nums from the function #
sub clean_ecs {
  my( $func ) = @_;
  my $ecs = [];
  while ( $func =~ s/\s*[\(\[]EC\s+([0-9\-\.]+)[\)\]],?//g ) {
    my $ec = $1;
    # only take them if no '-' is in there
    if ($ec !~ /\-/) {
      push( @$ecs, $1 );
  return ( $func, $ecs );
# get TC nums from the function #
sub clean_tcs {
  my($func) = @_;
  my $tcs = [];
  while ( $func =~ s/\s*[\(\[]TC\s+([a-zA-Z0-9\-\.]+)[\)\]],?//g ) {
    push(@$tcs,$1);
  return ( $func, $tcs );
__DATA__
ABC
TRAP
ATPase
ComM
CRISPR
C4
P6
OmpA
MotB
ATPase
YjeE
FKBP
SSU
LSU
NADH
DNA
RNA
rRNA
tRNA
mRNA
TRP
AmpG
AnkB
ApaG
Apo
AraC
ArdK
AsmA
AzlC
BarA
BatA
BatD
BolA
BsuBI
CapK
CbbY
CcdB
Ccm2
Che
CheW
ClpB
Cob
CopG
CreA
Cro
CtxA
CymA
CymJ
DamX
DedA
DedD
DinG
DnaJ
DnaK
ElaA
FlaF
FAD
FxsA
FyuA
GatB
GlcNAc
GlpG
GlpM
GTP
HflC
HflK
HigB
High
HipA
HlyD
IcmF
IncF
IncW
IstB
Kef
Kup
LppC
LptA
LuxA
LuxB
LuxC
LuxD
LuxE
LuxG
LysR
MadN
Maf
MiaB
Mlc
Mll3428
MotA
MoxR
Mrp
Mrr
MshO
MutT
Na+
NAD
NfuA
NhaP
NnrS
NupC
OpgC
OsmC
OxaI
ParA
ParE
PmbA
ProQ
PrpF
Psp
PutR
PvcB
PTS
RarD
Rare
RbmA
RbmD
RecA
RelB
RelE
RfbT
Rhs
RhsD
RloF
Rod
RstA
RstB
Rtn
O-antigen
SanA
SeqA
SgrR
Sll1503
Smp
SohB
SsrA
StrA
Sua5
Syd
TagA
TagE
TetA
TetD
Tfp
TldD
TnpA
Tol
TolA
TonB
TonB2
TorCAD
ToxR
TraA
TraD
TraE
TraF
TraG
TraH
TraI
TraO
Trk
TrkA
Trp
TyrA
VgrG
VirK
VvgS
WavQ
WblB
Wzy
Xaa
Ycg4D
YciO
YgfY
YihE
YjeF
Ync
Ynd
func:	BarA-associated response regulator UvrY (= GacA = SirA)))
prod:	BarA-associated response regulator UvrY
note:	Similar to UvrY, GacA, and SirA
func:	Putative cytoplasmic protein ,probably associated with Glutathione-regulated potassium-efflux
prod:	hypothetical protein
note:	Putative cytoplasmic protein, probably associated with Glutathione-regulated potassium-efflux
func:	Aminomethyltransferase (glycine cleavage system T protein)
prod:	aminomethyltransferase
note:	glycine cleavage system T protein
func:	Outer membrane protein YfgL, lipoprotein component of the protein assembly complex (forms a complex with YaeT, YfiO, and NlpB)
prod:	YfgL protein
note:	outer membrane protein
note:	lipoprotein component of the protein assembly complex; forms a complex with YaeT, YfiO, and NlpB
func:	50S ribosomal subunit maturation GTPase RbgA (B. subtilis YlqF)
prod:	50S ribosomal subunit maturation GTPase RbgA
func:	Survival protein surA precursor (Peptidyl-prolyl cis-trans isomerase surA)
prod:	peptidyl-prolyl cis-trans isomerase SurA
note:	survival protein surA precursor
func:	Glycine dehydrogenase [decarboxylating] (glycine cleavage system P protein)
prod:	glycine dehydrogenase [decarboxylating]
note:	glycine cleavage system P protein
func:	Flavohemoprotein (Hemoglobin-like protein) (Flavohemoglobin) (Nitric oxide dioxygenase)
prod:	flavohemoprotein
func:	Flavohemoprotein (Hemoglobin-like protein) (Flavohemoglobin) (Nitric oxide dioxygenase) (EC 1.14.12.17)
ecnu:	1.14.12.17
func:	Protein export cytoplasm chaperone protein (SecB, maintains protein to be exported in unfolded state)
prod:	chaperone protein SecB
note:	cytoplasmic protein
note:	maintains exported protein in unfolded state
func:	GlpG protein (membrane protein of glp regulon)
desc:	protein GlpG
note:	membrane protein of glp regulon
func:	BatA (Bacteroides aerotolerance operon)
prod:	protein BatA
note:	Bacteroides aerotolerance operon
func:	Putative inner membrane protein YjeT (clustered with HflC)
prod:	protein YjeT
note:	inner membrane protein
note:	clustered with HflC
func:	Putative inner membrane protein (Fragment)
func:	Proline dehydrogenase (Proline oxidase)
prod:	proline dehydrogenase
prod:	proline oxidase
func:	Signal recognition particle receptor protein FtsY (=alpha subunit) (TC 3.A.5.1.1)
desc:	signal recognition particle receptor protein FtsY
note:	alpha subunit
note:	TC 3.A.5.1.1
func:	Flavodoxin reductases (ferredoxin-NADPH reductases) family 1
prod:	ferredoxin-NADPH reductase
note:	flavodoxin reductases, family 1
func:	Ferredoxin-type protein NapF (periplasmic nitrate reductase)
prod:	nitrate reductase
desc:	ferredoxin-type protein NapF
note:	periplasmic
func:	Aminoacyl-histidine dipeptidase (Peptidase D)
prod:	aminoacyl-histidine dipeptidase
desc:	Peptidase D
prod:	signal recognition particle receptor protein FtsY
note:	alpha subunit
func:	23S rRNA (guanine-N-2-) -methyltransferase rlmL EC 2.1.1.-)
prod:	23S rRNA (guanine-N-2-)-methyltransferase rlmL
func:	Beta N-acetyl-glucosaminidase( EC 3.2.1.52 )
prod:	beta N-acetyl-glucosaminidase
ecnu:	3.2.1.52
func:	(U59485) AttH
func:	18K peptidoglycan-associated outer membrane lipoprotein
prod:	peptidoglycan-associated outer membrane lipoprotein
func:	OmpA/MotB precursor
prod:	OmpA precursor
func:	(GlcNAc)2 ABC transporter, periplasmic substrate-binding protein
prod:	(GlcNAc)2 ABC transporter: substrate-binding protein
func:	Peptidoglycan-associated lipoprotein precursor
prod:	Peptidoglycan-associated lipoprotein
func:	CRISPR-associated helicase Cas3, protein
prod:	CRISPR-associated helicase Cas3
func:	Homolog of E. coli HemX protein
prod:	HemX-like protein
func:	Homolog of E. coli HemY protein
prod:	HemY-like protein
func:	Hypothetical protein
func:	hypothetical protein
func:	conserved domain protein
func:	Conserved domain protein
func:	unknown
func:	predicted by FrameD
func:	Frataxin homolog CyaY, facilitates iron supply for heme A synthesis or Fe-S cluster assembly
prod:	frataxin CyaY
note:	facilitates iron supply for heme A synthesis or Fe-S cluster assembly
func:	ATPase YjeE, predicted to have essential role in cell wall biosynthesis
prod:	ATPase YjeE
note:	predicted to have essential role in cell wall biosynthesis
func:	Permease of the drug/metabolite transporter (DMT) superfamily
prod:	permease
desc:	permease of the drug/metabolite transporter (DMT) superfamily
func:	Permeases of the drug/metabolite transporter (DMT) superfamily
prod:	permease
func:	Phosphate transport regulator (distant homolog of PhoU)
prod:	phosphate transport regulator
note:	distant homolog of PhoU
func:	Unsaturated fatty acid biosythesis repressor FabR, TetR family
prod:	unsaturated fatty acid biosythesis repressor FabR
note:	TetR family regulator
func:	33 kDa chaperonin
prod:	heat-shock chaperonin
func:	Ribosome-associated heat shock protein implicated in the recycling of the 50S subunit (S4 paralog)
prod:	ribosome-associated heat shock protein
note:	implicated in the recycling of the LSU (S4 paralog)
func:	TRANSCRIPTION ACCESSORY PROTEIN (S1 RNA binding domain)
prod:	transcription accessory protein
note:	S1 RNA binding domain
func:	MiaB-like tRNA modifying enzyme YliG, TIGR01125
prod:	MiaB-like tRNA modifying enzyme YliG
note:	TIGR01125
func:	Phosphoribulokinase (EC 2.7.1.19) homolog, function unknown
note:	phosphoribulokinase homolog of unknown function
func:	Hydrolase, alpha/beta fold family functionally coupled to Phosphoribulokinase
prod:	alpha/beta fold family hydrolase
note:	functionally coupled to phosphoribulokinase
func:	LptA, protein essential for LPS transport across the periplasm
prod:	LptA protein
note:	essential for LPS transport across the periplasm
func:	Uncharacterized protein YrbK clustered with lipopolysaccharide transporters
prod:	YrbK protein
note:	clustered with lipopolysaccharide transporters
func:	Inner membrane protein YrbG, predicted calcium/sodium:proton antiporter
prod:	YrbG protein
note:	inner membrane protein, predicted calcium/sodium:proton antiporter
func:	Uncharacterized ABC transporter, periplasmic component YrbD
prod:	uncharacterized ABC transporter, periplasmic component YrbD
func:	Phosphate starvation-inducible protein PhoH, predicted ATPase
prod:	phosphate starvation-inducible protein PhoH
note:	predicted ATPase
func:	HD-GYP domain
prod:	HD-GYP domain-containing protein
func:	Predicted ATP-dependent endonuclease of the OLD family
prod:	ATP-dependent endonuclease
note:	predicted ATP-dependent endonuclease of the OLD family
func:	No significant database matches
func:	COG0110: Acetyltransferase (isoleucine patch superfamily)
prod:	acetyltransferase
note:	isoleucine patch superfamily
func:	Metalloprotease, putative zinc-binding domain
prod:	metalloprotease
note:	putative zinc-binding domain
func:	YjeF protein, function unknown
prod:	YjeF protein
func:	Phosphate ABC transporter, periplasmic phosphate-binding protein pstS (TC 3.A.1.7.1)
prod:	phosphate ABC transporter, periplasmic phosphate-binding protein pstS
note:	TC 3.A.1.7.1
func:	Methyl-accepting chemotaxis protein III (mcp-III) (ribose and galactose chemoreceptor protein)
prod:	methyl-accepting chemotaxis protein III
note:	ribose and galactose chemoreceptor protein
func:	ABC transporter, transmembrane region:ABC transporter:Peptidase C39, bacteriocin processing
prod:	ABC transporter transmembrane region
func:	fig|345076.3.peg.2944 homologs, predicted periplasmic protein
note:	predicted periplasmic protein
func:	Phosphosugar mutase of unknown sugar (see annotation)
prod:	phosphosugar mutase
note:	phosphosugar mutase of unknown sugar
func:	Maltoporin (maltose/maltodextrin high-affinity receptor, phage lambda receptor protein)
prod:	maltoporin
note:	maltose/maltodextrin high-affinity receptor, phage lambda receptor protein
func:	Predicted Lactate-responsive regulator, LysR family
prod:	transcriptional regulator LysR family
note:	predicted Lactate-responsive regulator
func:	Permease of the major facilitator superfamily
prod:	permease
note:	permease of the major facilitator superfamily
func:	Maltose/maltodextrin ABC transporter, substrate binding periplasmic protein MalE
prod:	maltose/maltodextrin ABC transporter substrate binding periplasmic protein MalE
func:	AraC-type DNA-binding domain-containing protein
prod:	AraC-type DNA-binding domain-containing protein
func:	Transposase and inactivated derivatives
prod:	transposase
func:	ABC-type phosphate transport system, periplasmic component
prod:	ABC-type phosphate transport system periplasmic component
func:	Arginine ABC transporter, periplasmic arginine-binding protein ArtI
prod:	arginine ABC transporter periplasmic arginine-binding protein ArtI
func:	Unknown, probable transcription regulator
desc:	probable transcription regulator
func:	orf, conserved hypothetical protein
func:	Iron-containing alcohol dehydrogenase
prod:	iron-containing alcohol dehydrogenase
func:	NnrS protein involved in response to NO
prod:	NnrS protein
desc:	involved in response to NO
func:	Uncharacterized protein, similar to the N-terminal domain of Lon protease
note:	similar to the N-terminal domain of Lon protease
func:	Holin-like protein cidA
prod:	holin-like protein cidA
func:	TRAP-type transport system, periplasmic component, predicted N-acetylneuraminate-binding protein
prod:	TRAP-type transport system periplasmic component
note:	predicted N-acetylneuraminate-binding protein
func:	TRAP-type transport system, small permease component, predicted N-acetylneuraminate transporter
prod:	TRAP-type transport system small permease component
note:	predicted N-acetylneuraminate transporter
func:	TRAP-type transport system, large permease component, predicted N-acetylneuraminate transporter
prod:	TRAP-type transport system large permease component
func:	Type III secretion inner membrane channel protein (LcrD,HrcV,EscV,SsaV)
prod:	Type III secretion inner membrane channel protein
note:	LcrD, HrcV, EscV, SsaV
func:	Type III secretion inner membrane protein (YscU,SpaS,EscU,HrcU,SsaU, homologous to flagellar export components)
prod:	Type III secretion inner membrane protein
desc:	homologous to flagellar export components
note:	YscU, SpaS, EscU, HrcU, SsaU
func:	Type III secretion cytoplasmic ATP synthase (EC 3.6.3.14, YscN,SpaL,MxiB,HrcN,EscN)
prod:	Type III secretion cytoplasmic ATP synthase
ecnu:	3.6.3.14
func:	NAD(FAD)-utilizing dehydrogenase, sll0175 homolog
prod:	NAD(FAD)-utilizing dehydrogenase
func:	thermostable direct hemolysin S
prod:	hemolysin S
func:	Putative predicted metal-dependent hydrolase
desc:	predicted metal-dependent hydrolase
func:	FKBP-type peptidyl-prolyl cis-trans isomerase fkpA precursor (EC 5.2.1.8)
prod:	FKBP-type peptidyl-prolyl cis-trans isomerase FkpA precursor
ecnu:	5.2.1.8
func:	FOG: WD40 repeat
func:	Protein slyX
prod:	protein SlyX
func:	Transporter, putative
prod:	transporter
func:	Type 4 fimbrial assembly protein pilC
prod:	type 4 fimbrial assembly protein PilC
func:	YgfY COG2938
func:	COG0354: Predicted aminomethyltransferase related to GcvT
prod:	predicted aminomethyltransferase related to GcvT
func:	Protein of unknown function DUF484
func:	Protein of unknown function DUF414
func:	Periplasmic/membrane protein associated with DUF414
func:	Thiosulfate sulfurtransferase glpE (EC 2.8.1.1)
prod:	thiosulfate sulfurtransferase GlpE
ecnu:	2.8.1.1
prod:	protein GlpG
func:	Flagellar biosynthesis protein fliL
prod:	flagellar biosynthesis protein FliL
func:	COG3165: Uncharacterized protein conserved in bacteria
func:	Uncharacterized protein conserved in bacteria
func:	Ferritin-like protein 2
prod:	ferritin-like protein 2
func:	LysR-family transcriptional regulator VC0068
prod:	LysR-family transcriptional regulator
func:	Protein crcB homolog
prod:	CrbC-like protein
func:	DNA-binding protein fis
prod:	NA-binding protein Fis
func:	COG3068: Uncharacterized protein conserved in bacteria
func:	O-antigen export system, ATP-binding protein
prod:	O-antigen export system ATP-binding protein
func:	O-antigen export system, permease protein
prod:	O-antigen export system permease protein
func:	O-antigen export system, polymerase or transferase
prod:	O-antigen export system polymerase or transferase
func:	Protein yicC
prod:	protein YicC
func:	Ferrichrome transport system permease protein fhuB (TC 3.A.1.14.3)
prod:	ferrichrome transport system permease protein FhuB
note:	TC 3.A.1.14.3
func:	Ferrichrome transport ATP-binding protein fhuC (TC 3.A.1.14.3)
prod:	ferrichrome transport ATP-binding protein FhuC
note:	TC 3.A.1.14.3
func:	HTH-type transcriptional regulator ilvY
prod:	HTH-type transcriptional regulator IlvY
func:	putative transcriptional regulator
func:	galactoside O-acetyltransferase (EC 2.3.1.18), probable yiiD
prod:	galactoside O-acetyltransferase
desc:	probable YiiD
ecnu:	2.3.1.18
func:	P pilus assembly/Cpx signaling pathway, periplasmic inhibitor/zinc- resistance associated protein
prod:	P pilus assembly/Cpx signaling pathway, periplasmic inhibitor/zinc- resistance associated protein
func:	ATP-dependent protease hslV (EC 3.4.25.-)
prod:	ATP-dependent protease HslV
func:	ATP-dependent hsl protease ATP-binding subunit hslU
prod:	ATP-dependent hsl protease ATP-binding subunit HslU
func:	Uncharacterized low-complexity protein
func:	Glutathione-regulated potassium-efflux system ancillary protein kefG
prod:	glutathione-regulated potassium-efflux system ancillary protein KefG
func:	Glutathione-regulated potassium-efflux system protein kefB
prod:	glutathione-regulated potassium-efflux system protein KefB
func:	FKBP-type peptidyl-prolyl cis-trans isomerase slyD (EC 5.2.1.8)
prod:	FKBP-type peptidyl-prolyl cis-trans isomerase SlyD
ecnu:	5.2.1.8
func:	Sodium-type polar flagellar protein motX
prod:	sodium-type polar flagellar protein MotX
func:	23S rRNA (guanosine-2'-O-) -methyltransferase rlmB (EC 2.1.1.-)
prod:	23S rRNA (guanosine-2'-O-) -methyltransferase RlmB
func:	Preprotein translocase secY subunit (TC 3.A.5.1.1)
prod:	preprotein translocase SecY subunit
note:	TC 3.A.5.1.1
func:	FKBP-type peptidyl-prolyl cis-trans isomerase fklB (EC 5.2.1.8)
prod:	FKBP-type peptidyl-prolyl cis-trans isomerase FklB
ecnu:	5.2.1.8
func:	Protein ytfJ precursor
prod:	protein YtfJ precursor
func:	Peptide methionine sulfoxide reductase msrA (EC 1.8.4.11)
prod:	peptide methionine sulfoxide reductase MsrA
ecnu:	1.8.4.11
func:	RNA polymerase sigma-54 factor rpoN
prod:	RNA polymerase sigma-54 factor RpoN
func:	Aspartate carbamoyltransferase regulatory chain (pyrI)
prod:	aspartate carbamoyltransferase regulatory chain PyrI
func:	RNA polymerase associated protein rapA (EC 3.6.1.-)
prod:	RNA polymerase associated protein RapA
func:	DNA primase; involved in replication, phage related
prod:	DNA primase
note:	phage related
func:	Zn-dependent protease
prod:	Zn-dependent protease
func:	Osmosensitive K+ channel histidine kinase kdpD (EC 2.7.3.-)
prod:	osmosensitive K+ channel histidine kinase KdpD
func:	COG0523: Putative GTPases (G3E family)
prod:	Putative GTPase (G3E family)
func:	H(+)/Cl(-) exchange transporter clcA
prod:	H(+)/Cl(-) exchange transporter ClcA
func:	relB protein
prod:	RelB protein
func:	mazG-related protein
prod:	MazG-related protein
func:	Sulfate and thiosulfate binding protein cysP
prod:	sulfate and thiosulfate binding protein CysP
func:	CcdB
prod:	CcdB protein
func:	Glycine dehydrogenase [decarboxylating] (glycine cleavage system P protein) (EC 1.4.4.2)
ecnu:	1.4.4.2
func:	C4-dicarboxylate like transporter
prod:	C4-dicarboxylate like transporter
func:	Anaerobic nitric oxide reductase transcription regulator norR
prod:	anaerobic nitric oxide reductase transcription regulator NorR
func:	Nucleoside permease nupC
prod:	nucleoside permease NupC
func:	frnE protein
prod:	FrnE protein
func:	hypothetical protein PA3071
func:	Uncharacterized protein similar to VCA0109
func:	Phosphate transport ATP-binding protein pstB (TC 3.A.1.7.1)
prod:	phosphate transport ATP-binding protein PstB
note:	TC 3.A.1.7.1
func:	Phosphate transport system permease protein pstA (TC 3.A.1.7.1)
prod:	phosphate transport system permease protein PstA
note:	TC 3.A.1.7.1
func:	Phosphate transport system permease protein pstC (TC 3.A.1.7.1)
prod:	phosphate transport system permease protein PstC
note:	TC 3.A.1.7.1
note:	TC 3.A.1.7.1
func:	ATP-dependent RNA helicase VCA0061
prod:	ATP-dependent RNA helicase
func:	ATP-dependent DNA helicase pcrA (EC 3.6.1.-)
prod:	ATP-dependent DNA helicase PcrA
func:	hcp protein
prod:	Hcp protein
func:	Predicted P-loop ATPase fused to an acetyltransferase COG1444
desc:	predicted P-loop ATPase fused to an acetyltransferase
func:	Na+/H+ antiporter NhaD type
prod:	Na+/H+ antiporter NhaD type
func:	ATP-dependent RNA helicase VCA0990
func:	Na+-driven multidrug efflux pump
prod:	Na+-driven multidrug efflux pump
func:	Peptidyl-prolyl cis-trans isomerase ppiC (EC 5.2.1.8)
prod:	peptidyl-prolyl cis-trans isomerase PpiC
ecnu:	5.2.1.8
func:	COG3385: FOG: Transposase and inactivated derivatives
prod:	transposase
func:	COG0055: F0F1-type ATP synthase, beta subunit
prod:	F0F1-type ATP synthase beta subunit
func:	Streptococcal hemagglutinin protein
prod:	hemagglutinin protein
func:	LysR-family transcriptional regulator VCA0830
func:	COG2827: putative endonuclease containing a URI domain
prod:	putative endonuclease containing a URI domain
func:	Autoinducer 2-binding periplasmic protein luxP precursor
prod:	autoinducer 2-binding periplasmic protein LuxP precursor
func:	Autoinducer 2 sensor kinase/phosphatase luxQ (EC 2.7.3.-) (EC 3.1.3.-)
prod:	autoinducer 2 sensor kinase/phosphatase LuxQ
func:	Molybdenum ABC transporter, periplasmic molybdenum-binding protein modA (TC 3.A.1.8.1)
prod:	molybdenum ABC transporter, periplasmic molybdenum-binding protein ModA
note:	TC 3.A.1.8.1
func:	Molybdenum transport system permease protein modB (TC 3.A.1.8.1)
prod:	molybdenum transport system permease protein ModB
note:	TC 3.A.1.8.1
func:	Molybdenum transport ATP-binding protein modC (TC 3.A.1.8.1)
prod:	molybdenum transport ATP-binding protein ModC
note:	TC 3.A.1.8.1
func:	Periplasmic protein torT precursor
prod:	periplasmic protein TorT precursor
func:	Sensor protein torS (EC 2.7.3.-)
prod:	sensor protein TorS
func:	COG4388: Mu-like prophage I protein
prod:	phage protein
desc:	Mu-like prophage I protein
func:	prophage MuSo2, virion morphogenesis protein, putative
prod:	phage protein
desc:	prophage MuSo2, virion morphogenesis protein, putative
func:	phage tail tape measure protein, TP901 family, putative
prod:	phage tail tape measure protein
desc:	TP901 family
func:	prophage MuSo2, 43 kDa tail protein, putative
prod:	phage tail protein
func:	Putative baseplate assembly protein
prod:	phage protein
desc:	putative baseplate assembly protein
func:	Protein-export membrane protein secD (TC 3.A.5.1.1)
prod:	protein-export membrane protein SecD
desc:	TC 3.A.5.1.1
func:	Protein-export membrane protein secF (TC 3.A.5.1.1)
prod:	protein-export membrane protein SecF
desc:	TC 3.A.5.1.1
func:	Anaerobic C4-dicarboxylate transporter dcuC
prod:	anaerobic C4-dicarboxylate transporter DcuC
func:	RRNA methylase, putative
prod:	rRNA methylase
func:	Oligopeptide transport system permease protein oppB (TC 3.A.1.5.1)
prod:	oligopeptide transport system permease protein OppB
desc:	TC 3.A.1.5.1
func:	Oligopeptide transport system permease protein oppC
prod:	oligopeptide transport system permease protein OppC
func:	Tyrosine recombinase xerD
prod:	tyrosine recombinase XerD
func:	Cell division protein ftsL
prod:   cell division protein FtsL
func:	Cell division protein ftsI [Peptidoglycan synthetase] (EC 2.4.1.129)
prod:	cell division protein FtsI [Peptidoglycan synthetase]
ecnu:	2.4.1.129
func:	Cell division protein ftsW
prod:	cell division protein FtsW
func:	Cell division protein ftsQ
prod:	cell division protein FtsQ
func:	Cell division protein ftsA
prod:	cell division protein FtsA
func:	Cell division protein ftsZ (EC 3.4.24.-)
prod:	cell division protein FtsZ
func:	Mutator mutT protein (7,8-dihydro-8-oxoguanine-triphosphatase) (EC 3.6.1.-)
prod:	MutT protein [7,8-dihydro-8-oxoguanine-triphosphatase]
func:	Aerobic respiration control sensor protein arcB (EC 2.7.3.-)
prod:	aerobic respiration control sensor protein ArcB
func:	Aerobic respiration control protein arcA
prod:	aerobic respiration control protein ArcA
func:	UPF0246 protein YaaA
func:	Chromosome segregation ATPase ## putative; UPF0325 protein yaeH
prod:	chromosome segregation ATPase
func:	Hypothetical protein Q8DBD3_VIBVU
func:	putative exported protein
func:	Flagellar biosynthesis protein flgN
prod:	flagellar biosynthesis protein FlgN
func:	Negative regulator of flagellin synthesis flgM
prod:	negative regulator of flagellin synthesis FlgM
func:	Flagellar basal-body P-ring formation protein flgA
prod:	flagellar basal-body P-ring formation protein FlgA
func:	Flagellar basal-body rod protein flgB
prod:	flagellar basal-body rod protein FlgB
func:	Flagellar basal-body rod protein flgC
prod:	flagellar basal-body rod protein FlgC
func:	Flagellar basal-body rod modification protein flgD
prod:	flagellar basal-body rod modification protein FlgD
func:	Flagellar hook protein flgE
prod:	flagellar hook protein FlgE
func:	Flagellar basal-body rod protein flgF
prod:	flagellar basal-body rod protein FlgF
func:	Flagellar basal-body rod protein flgG
prod:	flagellar basal-body rod protein FlgG
func:	Flagellar L-ring protein flgH
prod:	flagellar L-ring protein FlgH
func:	Flagellar P-ring protein flgI
prod:	flagellar P-ring protein FlgI
func:	Flagellar protein flgJ [peptidoglycan hydrolase] (EC 3.2.1.-)
prod:	flagellar protein flgJ [peptidoglycan hydrolase]
func:	Flagellar hook-associated protein flgK
prod:	flagellar hook-associated protein FlgK
func:	Flagellar hook-associated protein flgL
prod:	flagellar hook-associated protein FlgL
func:	Flagellin protein flaC
prod:	flagellin protein FlaC
func:	Flagellin protein flaD
prod:	flagellin protein FlaD
func:	Outer membrane protein NlpB, lipoprotein component of the protein assembly complex (forms a complex with YaeT, YfiO, and YfgL)
prod:	NlpB lipoprotein component of the protein assembly complex
note:	most likely function alternative not yet resolved
func:	Lipoprotein-34 precursor
prod:	lipoprotein
func:	Flagellin protein flaF
prod:	flagellin protein FlaF
func:	Flagellin protein flaG
prod:	flagellin protein FlaG
func:	Flagellar hook-associated protein fliD
prod:	flagellar hook-associated protein FliD
func:	Flagellar rod protein flaI
prod:	flagellar rod protein FlaI
func:	Flagellar biosynthesis protein fliS
prod:	flagellar biosynthesis protein FliS
func:	Flagellar regulatory protein fleQ
prod:	flagellar regulatory protein FleQ
func:	Flagellar sensor histidine kinase fleS
prod:	flagellar sensor histidine kinase FleS
func:	Flagellar hook-basal body complex protein fliE
prod:	flagellar hook-basal body complex protein FliE
func:	Flagellar M-ring protein fliF
prod:	flagellar M-ring protein FliF
func:	Flagellar motor switch protein fliG
prod:	flagellar motor switch protein FliG
func:	Flagellar assembly protein fliH
prod:	flagellar assembly protein FliH
func:	Flagellum-specific ATP synthase fliI
prod:	flagellum-specific ATP synthase FliI
func:	Flagellar protein fliJ
prod:	flagellar protein FliJ
func:	Flagellar hook-length control protein fliK
prod:	flagellar hook-length control protein FliK
func:	Flagellar motor switch protein fliM
prod:	flagellar motor switch protein FliM
func:	Flagellar motor switch protein fliN
prod:	flagellar motor switch protein FliN
func:	Flagellar biosynthesis protein fliO
prod:	flagellar biosynthesis protein FliO
func:	Flagellar biosynthesis protein fliP
prod:	flagellar biosynthesis protein FliP
func:	Flagellar biosynthesis protein fliQ
prod:	flagellar biosynthesis protein FliQ
func:	Flagellar biosynthesis protein fliR
prod:	flagellar biosynthesis protein FliR
func:	Flagellar biosynthesis protein flhB
prod:	flagellar biosynthesis protein FlhB
func:	Flagellar biosynthesis protein flhA
prod:	flagellar biosynthesis protein FlhA
func:	Flagellar biosynthesis protein flhF
prod:	flagellar biosynthesis protein FlhF
func:	Flagellar synthesis regulator fleN
prod:	flagellar synthesis regulator FleN
func:	5-methylaminomethyl-2-thiouridine-forming enzyme mnmC
prod:	5-methylaminomethyl-2-thiouridine-forming enzyme MnmC
prod:	Holin-like protein CidA
func:	Hypothetical protein ybgI
func:	Cytochrome c-type biogenesis protein CcmC, putative heme lyase for CcmE
prod:	cytochrome c-type biogenesis protein CcmC
desc:	desc: putative heme lyase for CcmE
func:	UPF0352 protein VC_2040
func:	Nucleoid-associated protein ndpA
prod:	nucleoid-associated protein NdpA
func:	Na+/H+ antiporter NhaC
prod:	Na+/H+ antiporter NhaC
func:	Peptide methionine sulfoxide reductase msrB (EC 1.8.4.6)
prod:	peptide methionine sulfoxide reductase MsrB
ecnu:	1.8.4.11
func:	Transcriptional regulator yidN, Cro/CI family
prod:	transcriptional regulator YidN, Cro/CI family
func:	COGs COG3492
func:	Cell division topological specificity factor minE
prod:	cell division topological specificity factor MinE
func:	Septum site-determining protein minD
prod:	septum site-determining protein MinD
func:	Septum site-determining protein minC
prod:	septum site-determining protein MinC
func:	Protein ycgL
prod:	protein YcgL
func:	Cytochrome c-type protein torY
prod:	cytochrome c-type protein TorY
func:	pvcA protein
prod:	PvcA protein
func:	ATP-dependent Clp protease ATP-binding subunit clpX
prod:	ATP-dependent Clp protease ATP-binding subunit ClpX
func:	Peptidyl-prolyl cis-trans isomerase ppiD (EC 5.2.1.8)
prod:	peptidyl-prolyl cis-trans isomerase PpiD
ecnu:	5.2.1.8
func:	Cell division protein ftsK
prod:	cell division protein FtsK
func:	Na+/H+-exchanging protein
prod:	Na+/H+-exchanging protein
func:	UPF0227 protein VC_1892
func:	Lipoprotein releasing system ATP-binding protein lolD
prod:	lipoprotein releasing system ATP-binding protein LolD
func:	Lipoprotein releasing system transmembrane protein lolE
prod:	lipoprotein releasing system transmembrane protein LolE
func:	UPF0434 protein VC_1876
func:	UPF0229 protein VC_1873
func:	Peptidyl-prolyl cis-trans isomerase ppiB (EC 5.2.1.8)
prod:	peptidyl-prolyl cis-trans isomerase PpiB
ecnu:	5.2.1.8
func:	Crossover junction endodeoxyribonuclease ruvC (EC 3.1.22.4)
prod:	crossover junction endodeoxyribonuclease RuvC
ecnu:	3.1.22.4
func:	tolB protein precursor, periplasmic protein involved in the tonb-independent uptake of group A colicins
prod:	TolB protein precursor
desc:	periplasmic protein involved in the tonb-independent uptake of group A colicins
func:	Surface presentation of antigens protein spaP
prod:	surface presentation of antigens protein SpaP
func:	Protein yciN
prod:	protein YciN
func:	Chaperone protein torD
prod:	chaperone protein TorD
func:	Chromosome partition protein mukF
prod:	chromosome partition protein MukF
func:	Chromosome partition protein mukE
prod:	chromosome partition protein MukE
func:	Chromosome partition protein mukB
prod:	chromosome partition protein MukB
func:	Probable zinc protease pqqL (EC 3.4.99.-)
desc:	probable zinc protease PqqL
func:	Mu-like prophage protein gp16
prod:	phage protein
desc:	Mu-like prophage protein Gp16
func:	Peptide transport system ATP-binding protein sapF (TC 3.A.1.5.5)
prod:	peptide transport system ATP-binding protein SapF
note:	TC 3.A.1.5.5
func:	Peptide transport system ATP-binding protein sapD (TC 3.A.1.5.5)
prod:	peptide transport system ATP-binding protein SapD
note:	TC 3.A.1.5.5
func:	Peptide transport system permease protein sapC (TC 3.A.1.5.5)
prod:	peptide transport system permease protein SapC
note:	TC 3.A.1.5.5
func:	Peptide transport system permease protein sapB (TC 3.A.1.5.5)
prod:	peptide transport system permease protein SapB
note:	TC 3.A.1.5.5
func:	Peptide transport periplasmic protein sapA (TC 3.A.1.5.5)
prod:	peptide transport periplasmic protein SapA
note:	TC 3.A.1.5.5
func:	FOG: EAL domain protein
prod:	EAL domain protein
func:	Na+ driven multidrug efflux pump
prod:	Na+ driven multidrug efflux pump
func:	Na+/H+ antiporter NhaA type
prod:	Na+/H+ antiporter NhaA type
func:	Diaminobutyrate-pyruvate transaminase & L-2,4-diaminobutyrate decarboxylase
prod:	diaminobutyrate-pyruvate transaminase/L-2,4-diaminobutyrate decarboxylase
func:	COG1451: Predicted metal-dependent hydrolase
func:	Sensor kinase citA, dpiB (EC 2.7.3.-)
prod:	sensor kinase CitA
func:	Transcriptional regulatory protein citB, dpiA
prod:	transcriptional regulatory protein CitB
func:	Potential queD like
desc:	potential QueD like
func:	Transcriptional regulator of alpha-acetolactate operon alsR
prod:	transcriptional regulator of alpha-acetolactate operon AlsR
func:	LysR-family transcriptional regulator VC1561
func:	SN-glycerol-3-phosphate transport ATP-binding protein ugpC (TC 3.A.1.1.3)
prod:	SN-glycerol-3-phosphate transport ATP-binding protein UgpC
note:	TC 3.A.1.1.3
func:	SN-glycerol-3-phosphate transport system permease protein ugpE (TC 3.A.1.1.3)
prod:	SN-glycerol-3-phosphate transport system permease protein UgpE
note:	TC 3.A.1.1.3
func:	SN-glycerol-3-phosphate transport system permease protein ugpA (TC 3.A.1.1.3)
prod:	SN-glycerol-3-phosphate transport system permease protein UgpA
note:	TC 3.A.1.1.3
func:	Putative methyl-accepting chemotaxis protein VC1535
desc:	putative methyl-accepting chemotaxis protein
func:	UPF0234 protein VC_1508
prod:	23S rRNA (guanine-N-2-) -methyltransferase RlmL
func:	Cytolysin-activating lysine-acyltransferase rtxC (EC 2.3.1.-)
prod:	cytolysin-activating lysine-acyltransferase RtxC
func:	Putative analog of CcoH, COG3198
desc:	putative analog of CcoH
func:	Spermidine Putrescine transport ATP-binding protein potA (TC_3.A.1.11.1)
prod:	spermidine putrescine transport ATP-binding protein PotA
desc:	TC_3.A.1.11.1
func:	Spermidine Putrescine ABC transporter permease component potB (TC_3.A.1.11.1)
prod:	spermidine putrescine ABC transporter permease component PotB
desc:	TC_3.A.1.11.1
func:	Spermidine Putrescine ABC transporter permease component potC (TC_3.A.1.11.1)
prod:	spermidine putrescine ABC transporter permease component PotC
desc:	TC_3.A.1.11.1
func:	ABC transporter, periplasmic spermidine putrescine-binding protein potD (TC_3.A.1.11.1)
prod:	ABC transporter periplasmic spermidine putrescine-binding protein PotD
desc:	TC_3.A.1.11.1
func:	Putrescine ABC transporter putrescine-binding protein potF (TC 3.A.1.11.2)
prod:	putrescine ABC transporter putrescine-binding protein PotF
desc:	TC_3.A.1.11.2
func:	hcp protein
prod:	Hcp protein
func:	Methyl-accepting chemotaxis protein II (mcp-II) (aspartate chemoreceptor protein)
func:	ATP-dependent RNA helicase VC1407
func:	FOG: HEAT repeat
func:	COG1092 family predicted tRNA methylase
desc:	predicted tRNA methylase
func:	FOG: CheY-like receiver
func:	probable lipoprotein YPO2292
func:	putative virK protein
desc:	putative VirK protein
func:	FIG002708: Protein sirB1
prod:	protein SirB1
func:	FIG002082: Protein sirB2
prod:	protein SirB2
func:	BarA sensory histidine kinase (= VarS = GacS)
prod:	BarA sensory histidine kinase
func:	Transport ATP-binding protein cydD
prod:	transport ATP-binding protein CydD
func:	Transport ATP-binding protein cydC
prod:	transport ATP-binding protein CydC
func:	Ribosomal large subunit pseudouridine synthase B (EC 5.4.99.-) (rRNA-uridine isomerase B) (rRNA pseudouridylate synthase B)
prod:	LSU pseudouridine synthase B
func:	COG0613, Predicted metal-dependent phosphoesterases (PHP family)
desc:	predicted metal-dependent phosphoesterases (PHP family)
func:	COG1801: Uncharacterized conserved protein
func:	ATP-dependent Clp protease ATP-binding subunit clpA
prod:	ATP-dependent Clp protease ATP-binding subunit ClpA
func:	ATP-dependent Clp protease adaptor protein clpS
prod:	ATP-dependent Clp protease adaptor protein ClpS
func:	UPF0274 protein VC_1127
func:	Probable protease htpX homolog (EC 3.4.24.-)
desc:	probable protease HtpX homolog
func:	Oligopeptide transport ATP-binding protein oppF (TC 3.A.1.5.1)
prod:	oligopeptide transport ATP-binding protein OppF
note:	TC 3.A.1.5.1
func:	Oligopeptide transport ATP-binding protein oppD (TC 3.A.1.5.1)
prod:	oligopeptide transport ATP-binding protein OppD
note:	TC 3.A.1.5.1
func:	Oligopeptide transport system permease protein oppC (TC 3.A.1.5.1)
note:	TC 3.A.1.5.1
note:	TC 3.A.1.5.1
func:	Oligopeptide ABC transporter, periplasmic oligopeptide-binding protein oppA (TC 3.A.1.5.1)
prod:	oligopeptide ABC transporter periplasmic oligopeptide-binding protein OppA
note:	TC 3.A.1.5.1
func:	Phosphonate ABC transporter phosphate-binding periplasmic component (TC 3.A.1.9.1)
prod:	phosphonate ABC transporter phosphate-binding periplasmic component
note:	TC 3.A.1.9.1
func:	FOG: GGDEF domain
prod:	GGDEF domain protein
func:	UPF0052 protein VC_1023
func:	Phosphorelay protein luxU
prod:	phosphorelay protein LuxU
func:	Regulatory protein luxO
prod:	regulatory protein LuxO
func:	Electron transport complex protein rnfA
prod:	electron transport complex protein RnfA
func:	Electron transport complex protein rnfB
prod:	electron transport complex protein RnfB
func:	Electron transport complex protein rnfC
prod:	electron transport complex protein RnfC
func:	Electron transport complex protein rnfD
prod:	electron transport complex protein RnfD
func:	Electron transport complex protein rnfG
prod:	electron transport complex protein RnfG
func:	Electron transport complex protein rnfE
prod:	electron transport complex protein RnfE
func:	Sodium-type flagellar protein motY precursor
prod:	sodium-type flagellar protein MotY precursor
func:	Phosphodiesterase yfcE (EC 3.1.4.-)
prod:	phosphodiesterase YfcE
func:	COG3118: Thioredoxin domain-containing protein
prod:	thioredoxin domain-containing protein
func:	HTH-type transcriptional regulator cueR
prod:	HTH-type transcriptional regulator CueR
func:	Cell division protein zipA
prod:	cell division protein ZipA
func:	Magnesium and cobalt efflux protein corC
prod:	magnesium and cobalt efflux protein CorC
func:	LPS-assembly lipoprotein rlpB precursor (Rare lipoprotein B)
prod:	LPS-assembly lipoprotein RlpB precursor
func:	COG0799: Uncharacterized homolog of plant Iojap protein
desc:	uncharacterized homolog of plant Iojap protein
func:	COG1576: Uncharacterized conserved protein ## ybeA
func:	Rod shape-determining protein rodA
prod:	rod shape-determining protein RodA
func:	UPF0250 protein VC_0945
func:	Capsular polysaccharide synthesis enzyme cpsD, exopolysaccharide synthesis
prod:	Capsular polysaccharide synthesis enzyme CpsD exopolysaccharide synthesis
func:	Capsular polysaccharide synthesis enzyme cpsC, polysaccharide export
prod:	Capsular polysaccharide synthesis enzyme CpsC polysaccharide export
func:	Capsular polysaccharide synthesis enzyme cpsB
prod:	Capsular polysaccharide synthesis enzyme CpsB
func:	Capsular polysaccharide synthesis enzyme cpsA, sugar transferase
prod:	Capsular polysaccharide synthesis enzyme CpsA sugar transferase
func:	Zn-ribbon-containing, possibly nucleic-acid-binding protein
prod:	Zn-ribbon-containing, possibly nucleic-acid-binding protein
func:	COG2363
func:	Thiamine biosynthesis protein thiI
prod:	thiamine biosynthesis protein ThiI
func:	Flagellar motor rotation protein motB
prod:	Flagellar motor rotation protein MotB
func:	Flagellar motor rotation protein motA
prod:	Flagellar motor rotation protein MotA
func:	UPF0178 protein VC_0881
func:	50S ribosomal protein L36 2
prod:	LSU ribosomal protein L36p
func:	COG1720: Uncharacterized conserved protein
func:	UPF0253 protein VC_0872
func:	relE protein
prod:	RelE protein
func:	Na(+)Citrate OH(-) antiporter
prod:	Na(+)Citrate OH(-) antiporter
func:	Cytoplasmic copper homeostasis protein cutC
prod:	cytoplasmic copper homeostasis protein CutC
prod:	phosphate ABC transporter, periplasmic phosphate-binding protein PstS
desc:	TC 3.A.1.7.1
func:	Phosphate regulon sensor protein phoR (EC 2.7.3.-)
prod:	phosphate regulon sensor protein phoR
func:	Phosphate regulon transcriptional regulatory protein phoB
prod:	phosphate regulon transcriptional regulatory protein PhoB
func:	Uncharacterized protein with LysM domain, COG1652
prod:	LysM domain-containing protein
func:	Trk system potassium uptake protein trkA
prod:	Trk system potassium uptake protein TrkA
func:	COG1272: Predicted membrane protein hemolysin III homolog
desc:	predicted membrane protein hemolysin III homolog
func:	Protein yihD
prod:	protein YihD
func:	16 kDa heat shock protein A
prod:	heat shock protein A
func:	tRNA uridine 5-carboxymethylaminomethyl modification enzyme gidA
prod:	tRNA uridine 5-carboxymethylaminomethyl modification enzyme GidA
func:	hypothetical conserved protein COG1739
func:	Na+/H+ antiporter, putative
desc:	Na+/H+ antiporter, putative
func:	Rod shape-determining protein mreB
prod:	rod shape-determining protein MreB
func:	Rod shape-determining protein mreC
prod:	rod shape-determining protein MreC
func:	Rod shape-determining protein mreD
prod:	rod shape-determining protein MreD
func:	NADH oxidoreductase hcr (EC 1.-.-.-)
prod:	NADH oxidoreductase Hcr
func:	COG0536: GTP-binding protein Obg
prod:	GTP-binding protein Obg
func:	Survival protein surA precursor (Peptidyl-prolyl cis-trans isomerase surA) (EC 5.2.1.8)
ecnu:	5.2.1.8
func:	Outer membrane protein Imp, required for envelope biogenesis
prod:	Imp required for envelope biogenesis
func:	Organic solvent tolerance protein precursor
prod:	organic solvent tolerance protein precursor
func:	UPF0269 protein yggX
func:	UPF0235 protein VC0458
func:	UPF0301 protein yqgE
func:	Protein sprT
prod:	protein SprT
func:	Iron-regulated virulence regulatory protein irgB
prod:	iron-regulated virulence regulatory protein IrgB
func:	Endopeptidase essential in most Bacteria (E. coli YgjD/B. subtilis YdiE)
prod:	endopeptidase
func:	Cell division protein ftsB
prod:	cell division protein FtsB
func:	5'-nucleotidase surE (EC 3.1.3.5)
prod:	5'-nucleotidase SurE
ecnu:	3.1.3.5
func:	Sulfate transport system permease protein cysT
prod:	sulfate transport system permease protein CysT
func:	Sulfate transport system permease protein cysW
prod:	sulfate transport system permease protein CysW
func:	Sulfate and thiosulfate import ATP-binding protein cysA (EC 3.6.3.25)
prod:	sulfate and thiosulfate import ATP-binding protein CysA
ecnu:	3.6.3.25
func:	Regulatory protein recX
prod:	regulatory protein RecX
func:	COG3105: Uncharacterized protein conserved in bacteria
func:	C4-type zinc finger protein, DksA/TraR family
prod:	C4-type zinc finger protein, DksA/TraR family
func:	Cell division protein ftsJ
prod:	cell division protein FtsJ
func:	Ribosomal RNA large subunit methyltransferase J (EC 2.1.1.-)
prod:	ribosomal RNA large subunit methyltransferase J
func:	Cell division protein ftsH (EC 3.4.24.-)
prod:	cell division protein FtsH
func:	COG0779: clustered with transcription termination protein NusA
prod:	clustered with transcription termination protein NusA
func:	COG4123: Predicted O-methyltransferase
prod:	predicted O-methyltransferase
func:	Protein of unknown function DUF81
func:	FKBP-type peptidyl-prolyl cis-trans isomerase slpA (EC 5.2.1.8)
prod:	FKBP-type peptidyl-prolyl cis-trans isomerase SlpA
ecnu:	5.2.1.8
ecnu:	3.2.1.52
func:	C-di-GMP phosphodiesterase MbaA, repressor of biofilm formation
prod:	C-di-GMP phosphodiesterase MbaA repressor of biofilm formation
func:	COG1496: Uncharacterized conserved protein
func:	Virulence factor mviN homolog
desc:	virulence factor MviN homolog
func:	Uncharacterized conserved protein
func:	UPF0260 protein BMEI0534
func:	UPF0181 protein VC_A0569
func:	UPF0067 protein yebR
func:	UPF0131 protein VC_2546
func:	UPF0114 protein VC_0208
func:	UPF0125 protein yfjF
func:	UPF0274 protein ycfC
func:	UPF0263 protein VC1208
func:	ISSod13, transposase
prod:	ISSod13 transposase
func:	iSSod13, transposase
func:	Zn-dependent protease with chaperone function
prod:	Zn-dependent protease with chaperone function
note:	TC 3.A.1.5.1
note:	TC 3.A.1.5.1
func:	ISSod2, transposase OrfB
prod:	ISSod2 transposase OrfB
func:	ISSod2, transposase OrfA
prod:	ISSod2 transposase OrfA
func:	Putative uncharacterized protein VC_A0360
func:	Mll3428 protein
func:	Cytochrome B561
prod:	cytochrome b561
func:	Iron(III) dicitrate transport system permease protein fecD (TC 3.A.1.14.1)
prod:	iron(III) dicitrate transport system permease protein FecD
note:	TC 3.A.1.14.1
func:	Na(+) H(+) antiporter subunit A; Na(+) H(+) antiporter subunit B
prod:	Na(+) H(+) antiporter subunit A/Na(+) H(+) antiporter subunit B
func:	Na(+) H(+) antiporter subunit B
prod:	Na(+) H(+) antiporter subunit B
func:	Na(+) H(+) antiporter subunit C
prod:	Na(+) H(+) antiporter subunit C
func:	Na(+) H(+) antiporter subunit D
prod:	Na(+) H(+) antiporter subunit D
func:	Na(+) H(+) antiporter subunit E
prod:	Na(+) H(+) antiporter subunit E
func:	Na(+) H(+) antiporter subunit F
prod:	Na(+) H(+) antiporter subunit F
func:	Na(+) H(+) antiporter subunit G
prod:	Na(+) H(+) antiporter subunit G
func:	Ribosyl nicotinamide transporter, pnuC-like
prod:	ribosyl nicotinamide transporter PnuC-like protein
func:	COG1683: Uncharacterized conserved protein / Hypothetical protein ybgA
func:	Dipeptide transport system permease protein dppC (TC 3.A.1.5.2)
prod:	dipeptide transport system permease protein DppC
note:	TC 3.A.1.5.2
note:	TC 3.A.1.5.1
func:	Metallo-beta-lactamase superfamily protein PA0057
prod:	metallo-beta-lactamase superfamily protein
func:	N-Acetyl-D-glucosamine ABC transport system, sugar-binding protein
prod:	N-Acetyl-D-glucosamine ABC transport system sugar-binding protein
func:	Thioredoxin-like protein clustered with PA0057
desc:	thioredoxin-like protein
func:	COG1559 protein yceG like
desc:	protein yceG like
func:	Na(+)-translocating NADH-quinone reductase subunit F (EC 1.6.5.-)
prod:	Na(+)-translocating NADH-quinone reductase subunit F
func:	Na(+)-translocating NADH-quinone reductase subunit E (EC 1.6.5.-)
prod:	Na(+)-translocating NADH-quinone reductase subunit E
func:	Na(+)-translocating NADH-quinone reductase subunit D (EC 1.6.5.-)
prod:	Na(+)-translocating NADH-quinone reductase subunit D
func:	Na(+)-translocating NADH-quinone reductase subunit C (EC 1.6.5.-)
prod:	Na(+)-translocating NADH-quinone reductase subunit C
func:	Na(+)-translocating NADH-quinone reductase subunit B (EC 1.6.5.-)
prod:	Na(+)-translocating NADH-quinone reductase subunit B
func:	Na(+)-translocating NADH-quinone reductase subunit A (EC 1.6.5.-)
prod:	Na(+)-translocating NADH-quinone reductase subunit A
func:	Peptidyl-prolyl cis-trans isomerase ppiA precursor (EC 5.2.1.8)
prod:	peptidyl-prolyl cis-trans isomerase PpiA precursor
ecnu:	5.2.1.8
func:	NADPH-dependent glutamate synthase, large subunit
prod:	NADPH-dependent glutamate synthase large subunit
func:	S-adenosyl-methyltransferase mraW (EC 2.1.1.-)
prod:	S-adenosyl-methyltransferase MraW
func:	Single-stranded-DNA-specific exonuclease recJ (EC 3.1.-.-)
prod:	single-stranded-DNA-specific exonuclease RecJ
func:	Hypothetical UPF0243 zinc-binding protein VP2529
desc:	hypothetical zinc-binding protein
func:	Hypothetical ATP-binding protein UPF0042, contains P-loop # frameshift
note:	hypothetical ATP-binding protein, contains P-loop
func:	LysR-family transcriptional regulator clustered with PA0057
func:	P pilus assembly/Cpx signaling pathway, periplasmic inhibitor/zinc-resistance associated protein
prod:	P pilus assembly/Cpx signaling pathway inhibitor/zinc-resistance associated protein
func:	Hypothetical lysR-family transcriptional regulator YdhB
func:	MG(2+) CHELATASE FAMILY PROTEIN
prod:	Mg(2+) chelatase family protein
func:	Tyrosine recombinase xerC
prod:	tyrosine recombinase XerC
func:	Cell division transporter, ATP-binding protein ftsE (TC 3.A.5.1.1)
prod:	cell division transporter ATP-binding protein FtsE
note:	TC 3.A.5.1.1
func:	Cell division protein ftsX
prod:	cell division protein FtsX
func:	Protein of unknown function DUF541
func:	Tetrapyrrole (Corrin-Porphyrin) methylase family protein UPF0011
prod:	tetrapyrrole (Corrin-Porphyrin) methylase family protein
func:	COG1132
func:	RloF
prod:	RloF protein
func:	Na+/H+ antiporter family protein
prod:	Na+/H+ antiporter family protein
func:	Hypothetical protein DUF454
func:	YciO family
prod:	YciO family protein
func:	VirK
prod:	VirK protein
func:	orf 104
func:	ABC-type amino acid transport, signal transduction systems, periplasmic component/domain
prod:	ABC-type amino acid transport system periplasmatic component
func:	Outer membrane protein ImpK/VasF, OmpA/MotB domain
prod:	ImpK/VasF outer membrane protein
func:	Phosphotransferase system mannitol/fructose-specific IIA domain
prod:	phosphotransferase system mannitol/fructose-specific IIA domain protein
func:	Fructosamine kinase family protein, At3g61080 homolog
prod:	fructosamine kinase family protein
func:	Starvation lipoprotein Slp paralog
prod:	starvation lipoprotein Slp like protein
func:	Transcriptional regulator, VCA0231 ortholog
func:	Translation elongation factor G paralog
prod:	translation elongation factor G-like protein
func:	Dihydrolipoamide acetyltransferase component of pyruvate dehydrogenase complex (EC 2.3.1.12)
prod:	dihydrolipoamide acetyltransferase component of pyruvate dehydrogenase complex
ecnu:	2.3.1.12
func:	Dihydrolipoamide succinyltransferase component (E2) of 2-oxoglutarate dehydrogenase complex (EC 2.3.1.61)
prod:	dihydrolipoamide succinyltransferase component (E2) of 2-oxoglutarate dehydrogenase complex
ecnu:	2.3.1.61
func:	Acylphosphate phosphohydrolase (EC 3.6.1.7), putative
prod:	acylphosphate phosphohydrolase
ecnu:	3.6.1.7
func:	Iron-containing alcohol dehydrogenase (EC 1.1.1.1)
ecnu:	1.1.1.1
func:	ABC-type nitrate/sulfonate/bicarbonate transport systems, periplasmic components
prod:	ABC-type transport system periplasmic component
func:	cAMP-binding proteins - catabolite gene activator and regulatory subunit of cAMP-dependent protein kinases
prod:	cAMP-binding protein
note:	catabolite gene activator and regulatory subunit of cAMP-dependent protein kinases
func:	GGDEF and EAL domain proteins
prod:	GGDEF and EAL domain-containing protein
func:	NAD(FAD)-utilizing dehydrogenases
func:	RTX toxins and related Ca2+-binding proteins
prod:	Ca2+-binding protein
note:	putative RTX toxin
func:	SAM-dependent methyltransferases
prod:	SAM-dependent methyltransferase
func:	ATP-dependent RNA helicase VCA0768
func:	Fe-S protein, homolog of lactate dehydrogenase SO1521
prod:	Fe-S oxidoreductase
note:	similar to lactate dehydrogenase SO1521
prod:	metallo-beta-lactamase family protein
note:	similar to PA00057
func:	Ycg4D
func:	4-Hydroxy-2-oxoglutarate aldolase (EC 4.1.3.16)
prod:	4-hydroxy-2-oxoglutarate aldolase
ecnu:	4.1.3.16
func:	2-dehydro-3-deoxyphosphogluconate aldolase (EC 4.1.2.14)
prod:	2-dehydro-3-deoxyphosphogluconate aldolase
ecnu:	4.1.2.14
func:	Biotin synthesis protein bioH
prod:	biotin synthesis protein BioH
func:	Biotin synthesis protein bioC
prod:	biotin synthesis protein BioC
func:	Cob(I)alamin adenosyltransferase (EC 2.5.1.17)
prod:	cob(I)alamin adenosyltransferase
ecnu:	2.5.1.17
func:	L-rhamnose operon transcriptional activator rhaR
prod:	L-rhamnose operon transcriptional activator RhaR
func:	Amide synthase component of siderophore synthetase # Vibriobactin-specific, VibH
prod:	amide synthase component of siderophore synthetase
desc:	vibriobactin-specific, VibH
func:	Phosphopantetheinyl transferase component of siderophore synthetase (EC 2.7.8.-) # Vibriobactin-specific, VibD
prod:	phosphopantetheinyl transferase component of siderophore synthetase
desc:	vibriobactin-specific, VibD
func:	Toxin co-regulated pilus biosynthesis protein T, putative ATP-binding translocase of TcpA
prod:	toxin co-regulated pilus biosynthesis protein T
desc:	putative ATP-binding translocase of TcpA
func:	Toxin co-regulated pilus biosynthesis protein F, putative outer membrane channel for TcpA extrusion
prod:	toxin co-regulated pilus biosynthesis protein F
desc:	putative outer membrane channel for TcpA extrusion
func:	TCP pilus virulence regulatory protein toxT, transcription activator, AraC family
prod:	TCP pilus virulence regulatory protein ToxT transcription activator AraC family
func:	TCP pilin signal peptidase, TcpA processing
prod:	TCP pilin signal peptidase TcpA processing
func:	Rare lipoprotein A precursor
prod:	rare lipoprotein A precursor
func:	N-acetylglucosamine-6P-responsive transcriptional repressor NagC, ROK family
prod:	N-acetylglucosamine-6P-responsive transcriptional repressor NagC ROK family
func:	RstA
prod:	RstA phage-related replication protein
func:	transcriptional repressor RstR
prod:	RstR phage-related transcriptional repressor
func:	S-adenosylmethionine-dependent methyltransferase Functionally Coupled to the MukBEF Chromosome Partitioning Mechanism
prod:	S-adenosylmethionine-dependent methyltransferase functionally coupled to the MukBEF chromosome partitioning mechanism
func:	Membrane Protein Functionally coupled to the MukBEF Chromosome Partitioning Mechanism
prod:	membrane protein functionally coupled to the MukBEF chromosome partitioning mechanism
func:	PvcA protein, related to known isonitrile synthases
prod:	PvcA protein
func:	PvcB protein, related to amino acid oxidizing enzymes
prod:	PvcB protein
func:	Cholera enterotoxin subunit B precursor (Cholera enterotoxin B chain) (Cholera enterotoxin gamma chain) (Choleragenoid)
prod:	Enterotoxin subunit B
func:	protein of unknown function
func:	Protein of unknown function Smg
func:	orf30
func:	orf29
func:	orf4
func:	FIG018583: protein of unknown function
func:	Cryptic phage CTXphi transcriptional repressor rstR
prod:	cryptic phage CTXphi transcriptional repressor RstR
func:	Outer membrane chaperone Skp (OmpH) precursor @ Outer membrane protein H precursor
prod:	outer membrane chaperone Skp (OmpH) precursor
func:	AAA ATPase, central region
prod:	AAA ATPase central region
func:	Wzy
prod:	Wzy protein
func:	50S ribosomal protein L33
prod:	LSU ribosomal protein L33p
func:	Ribosomal protein S12p Asp88 (E. coli) methylthiotransferase
prod:	ribosomal protein S12p Asp88 methylthiotransferase
func:	WavQ
prod:	WavQ protein
func:	NT01VC2352
func:	COG1301: Na+/H+-dicarboxylate symporters
prod:	Na+/H+-dicarboxylate symporter
func:	TorCAD operon transcriptional regulatory protein torR
prod:	TorCAD operon transcriptional regulatory protein TorR
func:	protein of unknown function DUF847
func:	Membrane protein, distant similarity to thiosulphate:quinone oxidoreductase DoxD
prod:	membrane protein, similar to thiosulphate:quinone oxidoreductase DoxD
func:	Similarities with Photorhabdus cytotoxin
prod:	cytotoxin-like protein
func:	Proline/sodium symporter PutP (TC 2.A.21.2.1) @ Propionate/sodium symporter
prod:	proline/sodium symporter PutP
note:	TC 2.A.21.2.1
func:	Chain A, Crystal Structure Of Protein Vc1899 From Vibrio Cholerae
func:	haemagglutinin associated protein
prod:	hemagglutinin associated protein
func:	TPR repeat
prod:	TPR repeat-containing protein
func:	COG0610: Type I site-specific restriction-modification system, R (restriction) subunit and related helicases
prod:	type I site-specific restriction-modification system R (restriction) subunit
func:	COG2369: Uncharacterized protein, homolog of phage Mu protein gp30
prod:	phage protein
func:	Ribonuclease HI, Vibrio paralog
prod:	ribonuclease HI
func:	COG1961: Site-specific recombinases, DNA invertase Pin homologs
prod:	site-specific recombinase
func:	COG1434: Uncharacterized conserved protein
func:	Trp operon repressor homolog
prod:	Trp operon repressor-like protein
func:	Hypothetical protein YqcC (clustered with tRNA pseudouridine synthase C)
func:	Sua5 YciO YrdC YwlC family protein
prod:	YrdC family protein
func:	FIG000859 (not subsystem-based): hypothetical protein
func:	Hypothetical protein colocalized with Enterobactin receptor VctA
func:	COG1004: Predicted UDP-glucose 6-dehydrogenase( EC:1.1.1.22 )
prod:	UDP-glucose 6-dehydrogenase
ecnu:	EC:1.1.1.22
func:
prod:
