[Bio] / FigKernelScripts / score_ifcs_mcauliffe.pl Repository:
Log of /FigKernelScripts/score_ifcs_mcauliffe.pl
Tue Aug 8 22:50:02 2006 UTC (13 years, 6 months ago) by overbeek
Changes since 1.1: +13 -2941 lines
RAE: correcting indirect functional coupling score
Sun Jul 23 01:01:14 2006 UTC (13 years, 7 months ago) by overbeek
RAE: More direct and indirect functional coupling scores
