[Bio] / FigKernelScripts / score_ifcs.pl Repository:
Log of /FigKernelScripts/score_ifcs.pl
Sun Jul 23 01:01:14 2006 UTC (13 years, 3 months ago) by overbeek
RAE: More direct and indirect functional coupling scores
Tue Dec 20 05:23:30 2005 UTC (13 years, 11 months ago) by overbeek
Changes since 1.2: +2721 -2638 lines
update to computation of indirecdt functional coupling
Mon Dec 5 18:56:38 2005 UTC (13 years, 11 months ago) by olson
Thu Dec 1 21:50:50 2005 UTC (13 years, 11 months ago) by overbeek
add indirect_functional_coupling
