[Bio] / FigKernelScripts / score_dfcs.pl Repository:
Log of /FigKernelScripts/score_dfcs.pl
Fri Jul 21 21:24:36 2006 UTC (13 years, 10 months ago) by overbeek
Changes since 1.2: +1 -42 lines
RAE: removing the header that should not be in the source
Mon Dec 5 18:56:38 2005 UTC (14 years, 5 months ago) by olson
Thu Dec 1 22:00:49 2005 UTC (14 years, 6 months ago) by overbeek
add direct functional coupling
