[Bio] / FigKernelScripts / salvage_subsystem_rows.pl Repository:
View of /FigKernelScripts/salvage_subsystem_rows.pl
Revision 1.5 - (download) (as text) (annotate)
Sat Jan 7 20:00:14 2006 UTC (14 years, 6 months ago) by overbeek
fix to salvaging subsystems
# Public License.
use FIG;
my $fig = new FIG;
my $usage = "usage: salvage_subsystem_rows From To Maps [ToData]";
# Foreach Subsystem in To (a directory of subsystems), if Subsystem is in From,
# then each row representing an organism in Mapping will be "salvaged" and added
# to Subsystem in To.  If ToData is included, then any subsystems in From, but not in To
# will be copied to To (deleting rows for genomes not in ToData)
 ($from    = shift @ARGV) &&
 ($to      = shift @ARGV) &&
 ($mapping = shift @ARGV)
    || die $usage;
my $tmpF = "$FIG_Config::temp/extract_subsystems.$$";
if (@ARGV == 1)
    open(TMP,">$tmpF")
	|| die "could not open $tmpF";
    while (defined($_ = <DATA>))
	print TMP $_;
    close(TMP);
    &copy_new($from,$to,$ARGV[0],$tmpF);
foreach $_ (`cat $mapping/*`)
    if ($_ =~ /^(fig\|(\d+\.\d+)\.peg\.\d+)\t(fig\|(\d+\.\d+)\.peg\.(\d+))$/)
	$old{$2} = $4;
	$map{$1} = $5;
opendir(SUBS,$to) || die "could not open $to";
@subs = grep { $_ !~ /^\./ } readdir(SUBS);
closedir(SUBS);
foreach $sub (@subs)
    next if (! -d "$from/$sub/spreadsheet");
    print STDERR "updating $sub\n";
    undef %salvaged;
    open(IN,"<$from/$sub/spreadsheet") || die "$from/$sub/spreadsheet";
    while (defined($_ = <IN>))
	if (($_ =~ /^(\d+\.\d+)\t(\S+)\t(.*)$/) && ($new = $old{$1}))
	    $var = $2;
	    @old_pegs = split(/\t/,$3);
	    @new_pegs = ();
	    foreach $peg (@old_pegs)
		if ($peg && ($pegN = $map{$peg}))
		    push(@new_pegs,"fig|$new\.peg\.$pegN");
		else
		    push(@new_pegs,"");
	    salvaged{$new} = join("\t",($new,$var,@new_pegs));
    close(IN);
    open(IN,"<$to/$sub/spreadsheet") || die "$to/$sub/spreadsheet";
    $/ = "\n//\n";
    @spreadsheet = <IN>;
    close(IN);
    open(OUT,">$to/$sub/spreadsheet") || die "$to/$sub/spreadsheet";
    for ($i=0; ($i < @spreadsheet); $i++)
	if ($i != 2)
	    print OUT $spreadsheet[$i];
	else
	    $_ = $spreadsheet[$i];
	    chomp;
	    @lines = split(/\n/,$_);
	    %in_already = map { $_ =~ /^(\d+\.\d+)/; $1 => 1 } @lines;
	    foreach $new (keys(%salvaged))
		if (($new =~ /^(\d+\.\d+)/) && (! $in_already{$1}))
		    push(@lines,$salvaged{$new});
	    print OUT join("\n",@lines),$/;
    close(OUT);
    $/ = "\n";
if (@ARGV == 1) { unlink($tmpF); }
sub copy_new {
    my($from,$to,$to_data,$tmpF) = @_;
    opendir(ORG,"$to_data/Organisms") || die "$to/Organisms does not exist";
    my @orgs = grep { $_ =~ /^\d+\.\d+$/ } readdir(ORG);
    closedir(ORG);
    opendir(FROM,$from) || die "could not open $from";
    my @subsystems = grep { $_ !~ /^\./ } readdir(FROM);
    closedir(FROM);
    foreach my $subsystem (@subsystems)
	if (! -d "$to/$subsystem")
	    print STDERR "copying $subsystem\n";
	    &filter_genomes("$from/$subsystem","$to/$subsystem",\@orgs,$subsystem,$tmpF);
sub filter_genomes {
    my($from,$to,$orgs,$subsystem,$tmpF) = @_;
    my $genomesF = "$FIG_Config::temp/genomes.$$";
    open(TMP,">$genomesF") || die "could not open $genomesF";
    foreach $org (@$orgs)
	print TMP "$org\n";
    close(TMP);
    my $rc = system("extract_genomes",$genomesF,$from,$to,$tmpF);
    if ($rc != 0)
	print STDERR "failed to copy $from $to\n";
    unlink($genomesF);
__DATA__
/^\S.*\S$/
	Alignments,erase
	Backup,erase
	/^[CEV].*$/,copy
	curation.log,copy
	notes,copy
	reactions,copy
	spreadsheet,filter_rows
	SubsystemDiagrams,copyR
	diagrams,copyR
	/^assignments*/,erase
	/^rowss*/,erase
	constructs,copyR
	rows,erase
	/\.log$/,copyR
	MAP_SUPPORT,copyR
	/^.*~$/,erase
