[Bio] / FigKernelScripts / runclustalw.pl Repository:
Log of /FigKernelScripts/runclustalw.pl
Mon May 7 00:43:26 2007 UTC (12 years, 10 months ago) by overbeek
Changes since 1.3: +3 -0 lines
add computation of alignments to building FIGFAMS
Mon Dec 5 18:56:38 2005 UTC (14 years, 3 months ago) by olson
Wed Apr 27 13:30:34 2005 UTC (14 years, 11 months ago) by overbeek
Changes since 1.1: +17 -5 lines
make runclustalw handle embedded stops
Mon Jan 17 01:27:44 2005 UTC (15 years, 2 months ago) by overbeek
add start prediction code
