[Bio] / FigKernelScripts / run_remote_Phobius_for_genome.pl Repository:
Log of /FigKernelScripts/run_remote_Phobius_for_genome.pl
Links to myrast_rel40: (view) (download) (as text) (annotate)
Wed Aug 22 22:05:51 2007 UTC (12 years, 9 months ago) by mkubal
for single genome
