[Bio] / FigKernelScripts / run_remote_Phobius_for_fasta.pl Repository:
Log of /FigKernelScripts/run_remote_Phobius_for_fasta.pl
Tue Jan 15 21:44:06 2008 UTC (12 years, 2 months ago) by mkubal
fasta file as input
