[Bio] / FigKernelScripts / run_remote_PHOBIOUS.pl Repository:
Log of /FigKernelScripts/run_remote_PHOBIOUS.pl
Thu Aug 16 15:59:26 2007 UTC (12 years, 6 months ago) by mkubal
runs Phobius computation for given geneome
