[Bio] / FigKernelScripts / run_rabbit_daemon.pl Repository:
Log of /FigKernelScripts/run_rabbit_daemon.pl
Fri Jan 20 21:44:25 2012 UTC (7 years, 10 months ago) by olson
CVS Tags: HEAD, mgrast_version_3_2, rast_rel_2014_0729, rast_rel_2014_0912
Changes since 1.4: +6 -0 lines
Add memcached support
Mon Jan 9 17:28:35 2012 UTC (7 years, 10 months ago) by olson
Changes since 1.3: +3 -0 lines
add support for limiting number of messages processed by server instance
Thu Oct 13 19:35:11 2011 UTC (8 years, 1 month ago) by olson
CVS Tags: mgrast_dev_10262011, mgrast_dev_12152011, mgrast_release_3_1_2
Changes since 1.2: +4 -3 lines
fix default vhost
add slow-server designation
Wed Oct 12 19:21:55 2011 UTC (8 years, 1 month ago) by olson
Changes since 1.1: +21 -1 lines
Add vhost support, change of cmdline
Tue May 3 17:09:33 2011 UTC (8 years, 6 months ago) by olson
CVS Tags: mgrast_dev_05262011, mgrast_dev_06072011, mgrast_dev_08022011, mgrast_dev_08112011, mgrast_release_3_1_0, mgrast_release_3_1_1, myrast_rel40, rast_rel_2011_0928
Driver script for running one of the RabbitMQ broker-based daemons.
