[Bio] / FigKernelScripts / run_peg_job_worker.pl Repository:
Log of /FigKernelScripts/run_peg_job_worker.pl
Links to caBIG-13Feb06-00: (view) (download) (as text) (annotate)
Mon Dec 5 18:56:38 2005 UTC (14 years, 4 months ago) by olson
Mon Feb 14 17:28:40 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.2: +9 -0 lines
New jobsched stuff.
Thu Feb 10 16:57:33 2005 UTC (15 years, 1 month ago) by olson
Changes since 1.1: +4 -83 lines
Change the test worker to use Cluster.pm instead of inline code.
Thu Feb 3 17:22:47 2005 UTC (15 years, 2 months ago) by olson
First cut at a database-based job scheduler.
